Author Topic: alarm keeps going off  (Read 3719 times)
osealy
  • dublin
« on: 14 July 2008, 19:15:48 »
Day or night, warm or cold, sometimes ok for a week sometimes every 5 mins. Tried disconnecting the hood catch, no help.
Can I just pull a fuse. And still keep the remote locking. I'm having to leave it unlocked at night.
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: alarm keeps going off
« Reply #1 on: 14 July 2008, 19:19:03 »
disconnect the powersounder, its the black box located under the scuttle (drivers side)
its most likely the internal batteries failing which can cause this
I completely binned mine!  The alarm still works through the horn backup anyways, so it wont cause any issues there.
Humbugs...
Danny
  • Wigan, Greater Manchester
« Reply #2 on: 14 July 2008, 19:19:31 »
or bonnet switch
PaulW
« Reply #3 on: 14 July 2008, 19:25:13 »
or bonnet switch
Said they already tried  ;)
Humbugs...
mike213735
« Reply #4 on: 14 July 2008, 19:31:11 »
Try disconnecting the wires that run to the rear windows. The ones actually in the estate part of the car.
Mike
« Reply #5 on: 14 July 2008, 19:35:00 »
Mike
yup, rear pane sensors on estate are rubbish
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #6 on: 14 July 2008, 20:08:24 »
might be worth wrapping some tape or something around the bonnet switch to keep it held in just to try it
Brian T
  • Addiscombe, Surrey
« Reply #7 on: 14 July 2008, 20:23:56 »
Do you, or have you heard 3 or 4 beeps when switching off the ignition?
Mine did this and it was a sign of the internal batery fainling in the power sounder
Illegitimis nil carborundum
osealy
  • dublin
« Reply #8 on: 14 July 2008, 21:40:37 »
pulled plugs off bck window. not goe off since, what is scuttle? does 97P have power sounder?
« Reply #9 on: 14 July 2008, 21:43:02 »
scuttle is the plastic panel at the bottom of the windscreen.i believe they all have a powersounder. :y
gsdtrainer
  • newport,s.wales
« Reply #10 on: 16 July 2008, 22:25:59 »
coincidence.......was reading this thread and thinking-mine does that sometimes and every so often i have 4 beeps when i turn the engine off-then my alarm went off.this scuttle ,is that inside the car or under the bonnet?can you renew the batteries?ta,terry
« Reply #11 on: 16 July 2008, 22:29:20 »
the panel is on the outside . black plastic between bottom of windscreen and top edge of the bonnet.you take the wipers off and then undo various little fasteners.afraid i dont know if batteries are renewable. :y
gsdtrainer
  • newport,s.wales
« Reply #12 on: 16 July 2008, 22:32:01 »
thanks albitz,will have a look tomorrow,when the sun comes out.
Brian T
« Reply #13 on: 16 July 2008, 22:36:34 »
I've read mixed reports elsewhere about replacing these bateries some involved the unit catching fire.
I think the general concensus is either replace it (the whole unit) or disconnect it.
I'm sure the more experienced oof'ers will confirm or deny.
osealy
  • dublin
« Reply #14 on: 21 July 2008, 00:58:47 »
Thanks mike44755678. Pulling off the window plugs did it. Simplest fix ever. If only I could sort out the cooling so easily.
