Author Topic: Repairing headlight adjusters  (Read 4776 times)
Matchless
  • Nottingham
    • A white van
« on: 16 July 2008, 16:25:45 »
Has anyone tried fitting the earlier white adjusters to a later projector headlamp?
Do they fit properly and give the correct adjustment range?
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: Repairing headlight adjusters
« Reply #1 on: 16 July 2008, 18:01:57 »
I'd be interested in the answer to that one as well.
Alan
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 16 July 2008, 18:22:52 »
yes i have and think they did adjust ok mabye they are a bit longer ! :y
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #3 on: 20 July 2008, 22:11:08 »
They fit ok but i'm yet to find out if they adjust enough :-/
bit iffy as the screw adjuster on projectors is about 10mm longer than old type and the white plastic piece is not held by lugs in housing (i'm not describing this very well :D)
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #4 on: 20 July 2008, 22:13:55 »
?? Changed my CD 98 for elite 96 today. What damage may I have done  :-[ ::)
HerefordElite
  • Hereford
« Reply #5 on: 20 July 2008, 22:31:14 »
that makes about as much sense as i did Dan ;D - what have you changed? the whole headlight? :-?
psychnurse
« Reply #6 on: 20 July 2008, 22:35:05 »
Changed the Cd estate (clear) lights for the yellow (96) elite lights
HerefordElite
  • Hereford
« Reply #7 on: 20 July 2008, 22:41:23 »
no probs swapping lights - my prob is i've bought 2 minifacelift projector lights off ebay (with broken internal adjusters >:() and replaced these with the adjusters from my old style headlights ;)
psychnurse
« Reply #8 on: 20 July 2008, 22:44:11 »
Ahh... I got it all wrong  :-[ :D
HerefordElite
  • Hereford
« Reply #9 on: 20 July 2008, 23:10:10 »
Sorry for the blatant thread hijack ;) - anybody got any tips on adjusting the headlights- like reversing back 10m from a wall and the beam should drop 1% etc???
cheers :y
« Reply #10 on: 21 July 2008, 08:22:56 »
cheers :y
Drive up to a wall so the bumper is pretty much touching it.
Place a coupld of pieces of tape on the wall where the light pattern starts to kick up (normaly a bright spot here).
Reverse back 4m ish and then adjust so the beams are in line with the tape markers but about 5-10mm lower than them.
Job done, works every time and passes the MOT.
HerefordElite
  • Hereford
« Reply #11 on: 21 July 2008, 09:44:56 »
cheers :y
thanks Mark  :y - what about horizontal adjusment coz these headlights have been apart and the adjusters are well out (i think :-/)
« Reply #12 on: 21 July 2008, 10:04:11 »
cheers :y
As said, adjust to point at the tape (it only needs to be about an inch long on the bright spot)......and to do this may require horizontal and vertical adjustment.....just set the vertical slightly below the tape  :y
HerefordElite
  • Hereford
« Reply #13 on: 21 July 2008, 11:01:50 »
cheers :y
sorry Mark I've re-read you original post and it all makes sense now :-[
LH kick up will indicate horizontal position and will move away from datum mark as i reverse :y
