Author Topic: france  (Read 1274 times)
Arpy
  • Preston
  • 02 2.2 cdx estate auto
france
« on: 21 July 2008, 22:16:01 »
going to france next month so will need a bulb kit any suggestions
Re: france
« Reply #1 on: 21 July 2008, 22:18:31 »
VX do one...
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: france
« Reply #2 on: 21 July 2008, 22:23:39 »
Don't VX do one?  Failing that, virtually all motor stores do them, usually contain ones you don't need, but generally go by the headlight bulb (i..e H1/H4/H7).
Given you normally don't get EVERYTHING you need, get the list of the external bulbs (from the handbook) and go to your local motor factors - might work out cheaper.  Doesn't have to be in a flashy case - any old box will do!
Usually, you'll need a headlamp bulb, and one of each of the external ones - given there are usually only 2 or (max) 3 types:
21W single (indicator, fog or brake light)
21/5W double (stop/tail, or tail/fog)
5W single - tail light
and normally a silly 5W capless for the front sidelight, usually the same for the side repeater.
Don't have a Drivers manual for mine, so don't quote me on the above - this is just from experience!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
