Author Topic: Timing Belt Problems  (Read 1886 times)
red62
  • Reading
« on: 19 July 2008, 16:19:35 »
Please see thread more help please i have knackered my engine on general chat
I have totally messed up I now can only turn the crank 45 degrees aether way
can I remove timing belt and line the individual cams up and set crank at TDC
or should I do a full strip down and build back up I do have the tools
Re: Timing Belt Problems
« Reply #1 on: 19 July 2008, 16:38:30 »
pm sent .mobile no if you need it. might be able to help, might. its in my out box tho does that mean its sent???
« Last Edit: 19 July 2008, 16:39:15 by chrisgixer »
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #2 on: 19 July 2008, 16:41:44 »
Yeah, been sent mate if its in outbox  :y
« Last Edit: 19 July 2008, 16:42:15 by psychnurse »
« Reply #3 on: 19 July 2008, 16:53:27 »
cheers nursey.
red,i have done my own belt. but retiming from scratch will be new to me. will give it a go tho. advise from others may help in the mean time.
from memory the cams have more than one set of marks?
is that the case? and how to distinguish.???
is it ok to move the cams via the allan key bolt in the cam sprocket???
and red. obviously crank the engine 2 or 3 times by hand with the crank nut first to make sure nothing bangs   before you think about firing it. if you get that far, obviously
red62
  • Reading
« Reply #4 on: 19 July 2008, 17:52:51 »
Tanks for the replys will giv it a go
Kind regards
Red
« Reply #5 on: 19 July 2008, 17:55:50 »
Shame you're not a bit closer, I'd have popped up and sorted it :'(
VX1
  • Reading, Berkshire
« Reply #6 on: 19 July 2008, 18:41:50 »
cheers nursey.
Chris have you got the cam lockin/timing kit? Oh by the I did see you the other day at three tuns mate.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
« Reply #7 on: 19 July 2008, 22:01:42 »
I could perhaps pop over and have a look, but I'm out tomorrow.  Could maybe do sometime on Monday (I'm off work next week).
« Reply #8 on: 19 July 2008, 22:23:46 »
cheers nursey.
Paul  :y
Nope... and yep, twas me. Thought i recognised the front of yours. :)
red62
  • Reading
« Reply #9 on: 21 July 2008, 22:40:26 »
Good Evening
Timing belt is done hurray and all working thanks to Kevin who took the time to come over and help me today it was much appreciated .
I would like to thank the rest of you for all your input
Cheers :D
« Reply #10 on: 21 July 2008, 22:42:10 »
Good outcome :y
« Reply #11 on: 22 July 2008, 11:19:50 »
 i replyed to your pm but a bit late me thinks, where did you go wrong?
 nice one kevin.    :y
