Author Topic: Here's some LPG injector pics for you DIY peeps...  (Read 3644 times)
The Cambelt Kid
  • Derby
« on: 20 July 2008, 00:05:57 »
And if you want the hi-res pics...
http://s164763218.websitehome.co.uk/omega/lpg_injector_pics.zip
This is my second LPG install and might have a Volvo on th way... ;D
Maybe i should go and take the LPGA training and exam, there's a few quid to be made me thinks...
« Last Edit: 20 July 2008, 00:08:44 by Omega2000w »
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
Re: Here's some LPG injector pics for you DIY peeps...
« Reply #1 on: 20 July 2008, 00:12:53 »
Nice work. :y
The Cambelt Kid
  • Derby
« Reply #2 on: 20 July 2008, 00:19:51 »
Thanks!
Shall i just post all of my pics?  then anyone can print them off ready for doing the job...?
I'd also be keen to know where people put the ECU, i bolted mine opposite the pollen filter and fed the wires through a large rubber grommet to the left into the HBV area.
« Last Edit: 20 July 2008, 00:20:15 by Omega2000w »
« Reply #3 on: 20 July 2008, 00:27:48 »
I put mine under the airbox - where the self levelling pump would be if I had one. These seem to be the only options really.
The Cambelt Kid
  • Derby
« Reply #4 on: 20 July 2008, 00:33:44 »
Wow, thats a lot of wires running about the engine bay.
Self leveling pump?  what's one of them?
« Reply #5 on: 20 July 2008, 00:36:37 »
Ah, the joys of MV6 ownership.  :y
The Cambelt Kid
  • Derby
« Reply #6 on: 20 July 2008, 00:48:15 »
I think i missed that one, i take it an MV6 doesn't have one?  :-[
Here a few more flicks anyway...  The one of the tank was my last 2.0GLS but my MV6 is just the same.
« Reply #7 on: 20 July 2008, 01:03:27 »
Correct. If you look up under the airbox, just in front of the front driver's side wheel there is a load of space up there. Jay W fitted the ECU and vapouriser there.
Dazzler
  • Haverhill, Suffolk
« Reply #8 on: 20 July 2008, 07:47:31 »
Some good pics there matey :y
So did you drill and tap from the underside of the manifold then i take it???
Looks a good job tho, may try that on my other manifold, once i get the car all up and running.
MutantCav
  • Gainsborough
« Reply #9 on: 20 July 2008, 08:24:56 »
Anyone need any 3.0 manifold with fuel rails for LPG conversion or just for practice then let me know, got a couple sitting around £20 including postage...
The Cambelt Kid
  • Derby
« Reply #10 on: 20 July 2008, 10:39:13 »
That's exactly where i put my vapouriser, i do have a water leak at the moment, so it'll be nice and easy to work with the car on stands.
The Cambelt Kid
  • Derby
« Reply #11 on: 20 July 2008, 10:43:35 »
Nope drilled from the top in the same direction as the petrol injectors, then countersunk the hole from the bottom.  Don't forget to use some threadlock....
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #12 on: 20 July 2008, 21:13:13 »
Was that a leaky shock absorber i saw there...(just changed mine so i can afford to be cocky) ;D
Omega 2.6 V6 Elite in Shiny Black
The Cambelt Kid
  • Derby
« Reply #13 on: 20 July 2008, 21:27:07 »
Not sure, i did th LPG install last autumn so may have been wet through earlier the day...
JueV6
  • Kent
« Reply #14 on: 21 July 2008, 07:22:37 »
Definatly a leaky shock. ;D ;D ;D
