Author Topic: Facelift Autobox  (Read 1523 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Facelift Autobox
« on: 22 July 2008, 13:51:43 »
Is there a schedule for changing/topping up the fluid. I only ask as a colleague said that they are designed to run for the life of the car.
Omega 2.6 V6 Elite in Shiny Black
Re: Facelift Autobox
« Reply #1 on: 22 July 2008, 13:56:05 »
they are designed to be 'sealed' for life, but a change at around 100k is worth while, and not too expensive.
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 22 July 2008, 13:56:52 »
They are a sealed for life box.
You can replace the fluid and filters tho, you need to drop the sumps to do this ;)
Some people do this every 40-60k, and some just leave well alone.
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« Reply #3 on: 22 July 2008, 15:06:10 »
After 176k changed oil and filter on mine and then had the Tech 2 update to version 9. mmmmmmmmmmm smooth as silk now
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 22 July 2008, 16:26:03 »
I quite fancy the tech 2 update....
Richard A
  • Aldridge, West Midlands
« Reply #5 on: 22 July 2008, 18:13:33 »
The Vauxhall 'Inspection System Book' ie the Service Record booklet that was with the car when new states 'Automatic Transmission Oil Change, 4-speed automatic transmission A25/35 (one or the other fitted to Omega's), "Under severe operating conditions the transmission oil should be changed every 70,000 miles".
So best advise, assume severe operating conditions and change the fluid & filter every 70k.  :y :y
regards
richard a
richard a
« Reply #6 on: 23 July 2008, 02:51:58 »
have seen threads on here, consensus was 60k
about right. If its banging a bit change it, or top up.
Depending when it was last done. Just done myn.
Laaaaarvly.
Ps dont want to speak for him but the boy is taking
Tech 2 to the wim knowledge day, i hear.
« Last Edit: 23 July 2008, 02:55:26 by chrisgixer »
