Author Topic: auto not changing gear sometimes  (Read 2386 times)
apollo996
« on: 22 July 2008, 21:29:42 »
hi, i have just bought a 2000 2.6v6 cdx AUTO estate and have a couple of questions/problems.  I bought it fairly cheap and it doesn't seem to change gear when pushing on.  not driven it far but it seems okay if driven slowly.  it also feels very slow....Looking at it I think it needs a good service and I plan to change oil (engine and gearbox) and clean out the breather system but any advice on the above problems.  no errors light on the dash or on the computer.
Re: auto not changing gear sometimes
« Reply #1 on: 22 July 2008, 21:39:51 »
First thing to check ... do  both the EML lights  ... 1 car with a spanner through the roof .. and .. 2. picture of an engine come on when you turn the ignition on without starting the engine, and go out after about 2-3 seconds ??
It is not unknown for some folks to remove these bulbs so the unwitting buyer does not know about faults.
Have a check and post back. If the lighhts don't both work there is a how-to on replacing the bulbs...
« Reply #2 on: 22 July 2008, 21:47:46 »
and it doesn't seem to change gear when pushing on.  not driven it far but it seems okay if driven slowly.   ......
Sounds about right to me.  :-/ If you drive with your foot burried into the carpet it will hang on to the gears longer than if you gently accelerate. Using 'sport' will empasise the late change, ie it will hang on to lower gears for even longer.
apollo996
« Reply #3 on: 22 July 2008, 22:08:02 »
the spanner through the roof doesn't light up at all but the engine light does come on and goes out again.  are you sure both lights are suppose to turn on?
« Reply #4 on: 22 July 2008, 22:15:37 »
That means the main EML (Engine Management Light) is NOT working .. it could well be trying to tell you something !!! ( the other one is the emissions control light)
Personally the first thing I would do is to fix that bulb !!
The 2.6 can't have the "paperclip" test done .. but on some you can read the codes by pressing both the brake and accelerator pedals fully down, then switching the ignition on without starting the engine .. the EML will flash a number of times to give the failure codes.
Of course, this can only be done if the EML light works !!! So, replace and test  :)
« Last Edit: 22 July 2008, 22:18:23 by entwood »
apollo996
« Reply #5 on: 22 July 2008, 22:19:39 »
Sorry its a 2.5 v6 - a typo.
    • 530D M Sport, 330i Coupe
« Reply #6 on: 22 July 2008, 22:21:39 »
When the bulb is replaced you can do the paperclip test  :y
Kieran
  • Dorset
« Reply #7 on: 22 July 2008, 22:25:17 »
When cold the gearbox does struggle to change. This is to allow the cats to warm up and protect them. After a while it should run smoothly, if not you have a problem
« Reply #8 on: 22 July 2008, 22:28:01 »
Then you are in luck ..  :)
Change/replace the EML bulb :
http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
Do the paperclip test :
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Post results up here ..  :y :y :y :y
apollo996
« Reply #9 on: 23 July 2008, 12:18:43 »
I can do this but can anyone confirm that both EML lights should be lit up?  On the clip to demonstrate the paperclip test I don't think both lit up do they?  Also, looking in the owners manual it says depending on model.  If would be great if someone could confirm for me.
« Reply #10 on: 23 July 2008, 12:21:41 »
They both light momentarily on switch on, and go out in about 2-3 seconds. This is a bulb check sequence, or you'd never know if the bulbs are blown (removed).
 :y :y :y
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #11 on: 23 July 2008, 12:30:09 »
I think your find the 2.5 only has one light.
« Reply #12 on: 23 July 2008, 12:32:27 »
whats mileage ? changed myn at 70k after a bit of slugishnss. They say every 60k on here. :y
apollo996
« Reply #13 on: 23 July 2008, 13:44:06 »
mileage reads 81k but i suspect it has done more.  I get no errors on the computer indicating gearbox problem.  I think I will clean everything out and change gearbox fluid.  Any other suggestions?
bigdods
  • Brackley
« Reply #14 on: 23 July 2008, 14:21:03 »
Yep, My 2.5 only ever had one light, same as my current 3.0. That second light is (IIRC) only for 2.6 and 3.2 versions.
