Author Topic: ingnition barrel swap  (Read 1365 times)
pete1666
  • Bridgwater Somerset
« on: 23 July 2008, 19:17:50 »
Hi i want to changed the ignition barrel , iknow i need to swap over the ECU but which one the one under the bonnet or in the drivers foot well?
and is there anything else i need to do?
Cheers Pete
Re: ingnition barrel swap
« Reply #1 on: 23 July 2008, 19:21:30 »
Cheers Pete
If you just want to change the igniton barrel then you dont need to touch anything electrical.
pete1666
« Reply #2 on: 23 July 2008, 20:14:32 »
I thought the key was coded to the immobilizer /alarm . i have 2 keys and 2 remotes from another omega and my one the barrel is past its best.
« Last Edit: 23 July 2008, 20:22:04 by pete1666 »
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #3 on: 23 July 2008, 20:18:35 »
It is ut it is a unit that sits around the barrel not actually part of the switch  :y
 A new barrel to match the original is only about £30 comes with a key but not the chip too
