Author Topic: How much lower are MV6 spring to Elite ones  (Read 1176 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 23 July 2008, 16:35:22 »
Does any one know how much lower the facelift MV6 springs or to the FL Elite set up. And also if the Shocks front and back any shorter.
Many thanks. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: How much lower are MV6 spring to Elite ones
« Reply #1 on: 23 July 2008, 17:06:09 »
Many thanks. :y
Some one needs to confirm this, but a figure of 30mm springs to mind from memory.
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #2 on: 23 July 2008, 19:20:16 »
15mm all round, but this is the difference between an MV6 and an Elite (Springs AND shcocks).
You may find you lose slightly more than this if your self-levelling was a bit on the high side.
It's not so much the ride height, but the ride itself that you're going to notice.
You can compare your car to mine this Friday when you're down mate. You can drive mine about a bit too to give you an idea. It won't be a direct comparison as my tryes are 235x35x19's and yours are standard, but you can chuck it around a couple of roundabouts which will give you a fair idea.
SP_3.2
  • Leicester
« Reply #3 on: 24 July 2008, 09:29:04 »
Thanks for that guys :y
See you on Friday and thanks for the offer that would be great.  :y
