Author Topic: My keys need replacing?  (Read 1008 times)
Sir Sideways
  • Sideways in Staffordshire
    • PFL 3.0 Auto Elite Estate
« on: 25 July 2008, 16:51:58 »
Hi Guys, the locking button on my key will not work. After taking it apart, I found the weld to be cracked. The door unlock and boot open buttons both work.
 Could I replace the fob with a new one, use the current blade and chip part with a new fob without having to get it recoded?. The other key fob has broken welds on the battery holder so it will not work at all. Ideally I could do with two new fobs.
Many Thanks
Jim
bigall
  • merseyside
Re: My keys need replacing?
« Reply #1 on: 25 July 2008, 17:33:18 »
the fob needs programming to the car - needs tech2 or a descent autolocksmith with the correct equipment
check locally with autolocksmiths I got mine (fob) and programmed to car for £45 iirc
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #2 on: 25 July 2008, 20:41:30 »
Sounds like it just needs a bit of soldering iron attention to me, i fixed my own that way...
Omega 2.6 V6 Elite in Shiny Black
« Reply #3 on: 25 July 2008, 20:51:42 »
A different fob will need programming via tech2.
You could send it off to Martin Imber who does a repair service on them
« Reply #4 on: 26 July 2008, 01:00:28 »
I will vouch for Martin's work . He has done both mine .. excellent work and damned fast as well.
Worth a PM :)   :y :y :y
