Author Topic: 2.5 and 3.0 LPG  (Read 1263 times)
tommycon
  • oldham
2.5 and 3.0 LPG
« on: 25 July 2008, 21:18:17 »
is there a difference between the LPG system for the 2.5 and 3.0 V6s?
 should have the 3L installed in my calibra in next couple of months and i`m going to install LPG,, not to sure if going DIY way or get the pro way.
 my calibra was originally a 2.5.
 cheers
HNO3GOH
  • Somerset
  • Play time.
Re: 2.5 and 3.0 LPG
« Reply #1 on: 26 July 2008, 00:06:59 »
Not that i can see. I have just put a second hand LPG system on a 2.5 and it come off a 3.0 so will know a little more in a day or so.
Re: 2.5 and 3.0 LPG
« Reply #2 on: 26 July 2008, 01:08:44 »
Injector nozzles are drilled according to engine capacity but not that critical. Other components are the same although normally an 8mm fuel line would be used on the 3.0 and the multivalve might be a bit marginal.
