Author Topic: Y26SE Engine parts Omega/ Vectra compatibility  (Read 7336 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« on: 10 February 2007, 12:09:59 »
I need to ensure that the thermostat and another associated part for my 2.6 vectra are the same as the 2.6 omegas.
Could someone confirm the following....
thermostat part number 24420652 from vectra 2.6  - is this only on the vectra 2.6 or is it the same part on 2.6 omega ( or 2.5 omega?)
Pipe running from thermostat outwards ( metal pipe) part number 90411829 - same info required.
Oh and can anyone actually tell me what 90411829 is called ? a vx price would also be mega......
 :y :y :)
JasonH
Re: Y26SE Engine parts Omega/ Vectra compatibility
« Reply #1 on: 10 February 2007, 15:45:25 »
Unfortunately the info I have says:
90411829 is COVER, TIMING BELT, FRONT, LOWER (for 1.4 and 1.6 engines)
And
24420652 is Vectra only (for 2.5 and 2.6)
Markie
« Reply #2 on: 10 February 2007, 15:57:15 »
And
i may have taken the number down wrong  :-/ could you try 90411629?
cheers
JasonH
« Reply #3 on: 10 February 2007, 18:14:18 »
90411629 is PIPE THERMOSTAT HOUSING TO HOSE
It's for X25XE, Y26SE, X30XE,  Y32SE
Vectra, Omega and Sintra
« Reply #4 on: 11 February 2007, 10:22:09 »
All the V6 stats and housings are the same......
Probably mentioned this before but, the actual stat insert is the same as the 4 pot ones (which is cheaper) and can be swapped over if the housing is ok....
Markie
« Reply #5 on: 11 February 2007, 16:40:43 »
thanks guys  :y
Mark you have mentioned this before i take it the stat is easy enought to remove from housing and swap over? never really studied them in great detail... :-X
« Reply #6 on: 11 February 2007, 17:05:18 »
Yes it is....press it in and twist...its a bayonet style fitting....
Markie
« Reply #7 on: 11 February 2007, 18:14:54 »
Thanks Mark - got the old stat out quite easy - think i will go down this route to renew  :y
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #8 on: 26 July 2008, 17:53:51 »
Sorry to be a pain but does the thermostat fit into the end of the metal housing or into the top hose attached to it from the radiator as my thermostat is missing?
What is the metal pie on the back of the engine they are talking about too?
Regards
Ray
