Pages: 1 2 [3] 4 5 6 7 8   Go Down
Author Topic: 2.5TD ECU Photos, help reqd. if possible!  (Read 20363 times)
Re: 2.5TD ECU Photos, help reqd. if possible!
« Reply #30 on: 13 May 2008, 22:05:56 »
Makes it a drivable car, rather than the slug it is.  That particular map you have is very impressive, particularly in a manual.  Shame I cannot run that map in my 428 ECU  :'(
Cheshley
  • Doncaster
« Reply #31 on: 14 May 2008, 07:29:07 »
I WANT ONE!!!!!!!!!!!!   (don't tell the missus tho)   ;D
platty
  • Cambridge
    • BMW 530d Sport
« Reply #32 on: 14 May 2008, 18:06:17 »
Get one and tell the missus too, cos for what they cost you will get your money back after about 5 tankfuls of juice. The economy is so much better.
I was crusing the motorway today at 80 and the MID was reading 60 mpg (take it with a pinch of salt) - it used to read about 35 at that speed.  :)
Omegatoy
  • UK
« Reply #33 on: 14 May 2008, 19:04:31 »
it will use less fuel when cruising mate, cos the engine isnt working as hard as it used to :y!!!
« Reply #34 on: 14 May 2008, 21:50:47 »
yup, economy jumped on mine.  no idea how accurate mid is, as I never fill it - too lazy, use pay at pump, and can never get enough fuel in to fill....
« Reply #35 on: 14 May 2008, 21:52:19 »
border line if you have a 427 or 428 ecu (last 3 digits of Bosch part number). 428 needs a bit of soldering.
Also, if you have an auto, forget it....
Cheshley
  • Doncaster
« Reply #36 on: 15 May 2008, 16:24:04 »
Nope, mine is Manual.  Where do I find the ECU's to find out which one I've got?
platty
  • Cambridge
    • BMW 530d Sport
« Reply #37 on: 15 May 2008, 20:40:21 »
Open up the bonnet, and on the right hand side (as you look into the engine bay), behind the battery is a triangular shaped plastic fuse box. Open this up and the ECU is on its side in there (silver), pull it upwards and it slides out so that you can see the serial number (X XXX XXX XXX)
If you want to check if it is socketed or not, then you will have to unplug it, bend back the metal tabs and open it up full (T8 & T20 Torx reqd.)
Hope that helps  :y
« Last Edit: 15 May 2008, 20:41:48 by platty »
Cheshley
  • Doncaster
« Reply #38 on: 15 May 2008, 22:02:30 »
Hope that helps  :y
Sweet, I had knee surgery yesterday so it's gonna be a few days at least before I'm out and under the bonnet again but I'll have a look as soon as I can and see where it goes from there.  If you don't mind me asking, what ballpark figure are we talking about for getting the car chipped?
Thanks
« Reply #39 on: 16 May 2008, 08:52:50 »
Hope that helps  :y
Thanks
find out which ecu it is first, if its 428, then you'll need to solder in a socket....
DJ Pete
  • Chelmsford, Essex.
« Reply #40 on: 16 May 2008, 08:57:20 »
This might be a stupid question, but are the TD ECUs interchangeable?
ie - if you have a 428, can you simply change it for one that does have a socket?
« Reply #41 on: 16 May 2008, 09:08:32 »
simple anser is no.
more complex answer - possibly. You'd have to swap immobiliser and transponders as well.  never tried, but may have a go myself.
Omegatoy
  • UK
« Reply #42 on: 16 May 2008, 12:07:27 »
simple anser is no.
early ones is yes dont know about later ones tho!!! :y
« Reply #43 on: 16 May 2008, 20:57:36 »
simple anser is no.
Ones with IR remotes, very easy. But then, they are all socketed chips anyway ;)
Later RF ones have a much more complex setup with the immobiliser.
platty
  • Cambridge
    • BMW 530d Sport
« Reply #44 on: 18 May 2008, 21:23:03 »
Economy great on a run, pic taken after 75 miles  :y
Due to a dodgy MID, the "3" at the front is actually an 8  :)
Pages: 1 2 [3] 4 5 6 7 8   Go Up
Page created in 0.025 seconds with 14 queries.
