Pages: 1 2 3 [4] 5 6 7 8   Go Down
Author Topic: 2.5TD ECU Photos, help reqd. if possible!  (Read 20373 times)
Cheshley
  • Doncaster
Re: 2.5TD ECU Photos, help reqd. if possible!
« Reply #45 on: 18 May 2008, 21:28:48 »
 :o
had you filled the boot as well as the tank with diesel!!!!!!   ;D ;D ;D
platty
  • Cambridge
    • BMW 530d Sport
« Reply #46 on: 18 May 2008, 21:34:15 »
 ;D It surprised me when I flicked through the MID
« Reply #47 on: 18 May 2008, 21:37:27 »
I've had mine read over 700miles even after I've done 100miles on the tank :y
Cheshley
  • Doncaster
« Reply #48 on: 18 May 2008, 21:38:30 »
I've got to get me one of those new fangled chips.  I'm still on crutches but getting about a bit better so hoping to get out and have a look at the ECU tomorrow.   :y
platty
  • Cambridge
    • BMW 530d Sport
« Reply #49 on: 18 May 2008, 21:41:49 »
I think if I drive real carefully I might be able to get 1000 on there  ;D
DJ Pete
  • Chelmsford, Essex.
« Reply #50 on: 19 May 2008, 11:11:27 »
Looks like I need to find an AR35 gearbox then!
My ECU doesn't seem to have 427/428 on it though.
I've got :
0 281 001 215
90 379 298
Does that mean anything to anyone?
« Reply #51 on: 19 May 2008, 11:13:48 »
I've got :
0 281 001 215
90 379 298
Older U25DT engine (no MAF), 215 ECU.
DJ Pete
« Reply #52 on: 19 May 2008, 11:19:59 »
So is it chippable?
« Reply #53 on: 19 May 2008, 11:51:27 »
So is it chippable?
yup.  pretty certain its socketed as well.  IIRC, Omegatoy's is a 215...
Omegatoy
  • UK
« Reply #54 on: 19 May 2008, 14:35:23 »
So is it chippable?
OH YES !!! and without a Maf There are certain other areas tht can be played with without the Maf pulling it back down!!! :y
« Reply #55 on: 19 May 2008, 14:56:34 »
So is it chippable?
You been buggering with the crude waste gate setup?
« Reply #56 on: 19 May 2008, 15:03:06 »
So is it chippable?
Would we do such a thing ::)
DJ Pete
« Reply #57 on: 19 May 2008, 15:24:24 »
So is it chippable?
Please tell me more!
« Reply #58 on: 19 May 2008, 15:27:09 »
So is it chippable?
I am surprised it didn't throw an over boost fault code from the inlet pressure sensor
« Reply #59 on: 19 May 2008, 15:33:50 »
So is it chippable?
Imagine the simplest most crude waste gate setup you have ever seen and then simplify it!
On the diseasel, the waste gate is normally closed and only opens as the boost pressure increases. The actual actuator is fed off the turbo boost pressure so as the inlet pressure rises, the waste gate opens therefore reducing the turbos rpm and maintaining a constant boost.
So, if you bugger about with the waste gate actuator then you can up the boost........dont overdo it though or you risk over revving the turbo!
Heres where it gets a little more difficult though, around 1997ish, a MAF was added to the setup to reduce smoke on full chat (to meet the regulations that were coming in) and this monitors the airflow. If it gets a bit high, it backs the fueling off to stop unburnt fuel exiting out the back James Bond style in a cloud of black smoke (because the smoke you see is unburnt fuel!)
This 'improvement' makes it harder to tune the old slug as your always fighting a few lines in code that are backing the fueling off!
« Last Edit: 19 May 2008, 15:35:33 by Mark »
Pages: 1 2 3 [4] 5 6 7 8   Go Up
