Author Topic: flywheel sensor  (Read 1608 times)
irratic
  • STOKE-ON-TRENT
flywheel sensor
« on: 26 July 2008, 14:08:15 »
can anyone tell me where/which is the plug for the flywheel sensor? trying do a mates car at side of road. but the sensor cable seems to go up under the exhaust manifold area. just wanted plug the new sensor in, connect it first to see if it starts.. paperclip test cam back as no rpm..
Grumpy
  • Manchester
Re: flywheel sensor
« Reply #1 on: 26 July 2008, 14:29:32 »
I assume you mean the Crank sensor?
It's next to the oil filter.
http://www.omegaowners.com/forum/YaBB.pl?num=1193589434
irratic
  • STOKE-ON-TRENT
Re: flywheel sensor
« Reply #2 on: 26 July 2008, 16:02:33 »
thats the one mate. got that bit.. but where does the other end go????
Re: flywheel sensor
« Reply #3 on: 26 July 2008, 16:04:19 »
irratic
  • STOKE-ON-TRENT
Re: flywheel sensor
« Reply #4 on: 27 July 2008, 09:30:56 »
could someone clarify exactly which plug it connects to????? or is there only one it can connect to??? and is it at rear of engine above the dis pac??
rickyboy
  • Glasgow
Re: flywheel sensor
« Reply #5 on: 27 July 2008, 11:18:49 »
"The connector end of the sensor is located at the rear of the engine and improved access can be gained by removing the wiper arms and scuttle cover".
irratic
  • STOKE-ON-TRENT
Re: flywheel sensor
« Reply #6 on: 27 July 2008, 11:32:17 »
cheers lads. as i understand it is the crank sensor goes down it stops the fuel and spark?? is this correct? and is it true that the cam sensor will show the same faults??? thanks for your help lads
jonathanh
  • coventry
Re: flywheel sensor
« Reply #7 on: 27 July 2008, 13:11:10 »
you'll get different fault codes for cam and crank sensor
I think the general wisdom on the V6 is that the cam sensor is robust but the crank sensor is not.
hope this helps
irratic
  • STOKE-ON-TRENT
Re: flywheel sensor
« Reply #8 on: 27 July 2008, 13:11:37 »
just to end the thread. car is now running. changed the crank sensor and started first turn... thanks for all your help
