Author Topic: ECU swap  (Read 1832 times)
pete1666
  • Bridgwater Somerset
ECU swap
« on: 27 July 2008, 19:13:54 »
Will there be any problem swapping the ecu under the bonnet from a 3.0 Elite to a 2.5 CD? i ve got 2 remote fobs can i set them up or do i need a Tech 2?
Cheers Pete
vauxfan2k
  • Western Isles
Re: ECU swap
« Reply #1 on: 27 July 2008, 22:11:51 »
The 2.5 CD ecu will not run the 3.0, the other way round maybe. The keyfobs are matched to the central locking unit not the ecu, if you can get the central locking unit from the car you got the fobs from and fit it, then your fobs will work (without re programming)
cheers
Steve
pete1666
Re: ECU swap
« Reply #2 on: 27 July 2008, 22:33:06 »
Hi, where is the central locking unit located.
Cheers Pete ;D
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: ECU swap
« Reply #3 on: 27 July 2008, 22:48:54 »
The control module is located behind the drivers kickpanel, you need to remove the vauxhall sil plate from the side, undo the torx screws from the panel below, then underneath near the front is another torx screw, remove that.  I think its a T15 torx screwdriver you need...
Then by the accelerator is another torx screw, remove that, then pull the panel out.
The module is then secured in underneath the harness for the stereo, there are 2x10mm plastic nuts which need removing, then you can gain access to remove it.
Humbugs...
pete1666
Re: ECU swap
« Reply #4 on: 27 July 2008, 22:58:20 »
Thanks for that  i will have a go tomorrow.
cheers
pete1666
Re: ECU swap
« Reply #5 on: 29 July 2008, 00:17:41 »
Hi swapped the ECU tickover was a bit higher and it seems more responsive ,
central locking sorted key fobs working, result
Pete
