Author Topic: check coolant!?!?  (Read 1836 times)
Snips
  • Nottingham / Stoke - on -Trent
check coolant!?!?
« on: 29 July 2008, 13:26:20 »
every day "coolant level" will come up on my dash, so the next day i will check the level while the engine is cold the its fine. ill start the engine to allow the fluid to move around and its still at the max line
any ideas on why this message keep popping up
cheers snips
hotel21
  • The Kingdom of Fife
Re: check coolant!?!?
« Reply #1 on: 29 July 2008, 13:29:20 »
Probably a faulty level sensor in the base of the expansion tank, if the fluid level is 100% OK.
As I recall, the header needs to be replaced in entirety as the sensor is not available seperatly....
craig
  • north wales/connah's quay
« Reply #2 on: 29 July 2008, 13:31:13 »
the same is happening to mine aswell!!! ::)sometimes it comes on sometimes it doesn't,but like snips,my coolant is spot on with no leaks etc....
Snips
« Reply #3 on: 29 July 2008, 13:49:27 »
cheers hotel21, ill see about gettin it sorted, as one day im going to ignore it and it will be low!
ians
  • Reading
« Reply #4 on: 29 July 2008, 14:37:26 »
check that the float in the tank is floating. It may have got stuck.
Otherwise its a new tank (or just unclip and short the sensor wiring from the bottom ;))
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #5 on: 29 July 2008, 22:38:32 »
mine does that to sometimes it comes on then it doesnt.is there any easy way of fixing it rather than changing the header tank
Used  to have  two v6 and they roared
Now got 2.5 to Opel
« Reply #6 on: 29 July 2008, 23:21:58 »
Giving your header tank a soak in a caustic cleaner. It helped, but didn't fix it. Besides, a new header tank looks so much better.  :y
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #7 on: 30 July 2008, 07:25:48 »
supose a new one does look better ive not realy looked at how to change it is it just a few jublie clips and a few securing bolts
Now got 2.5 to Opel
« Reply #8 on: 30 July 2008, 08:25:59 »
It's not even that. There's a hairgrip looking clip at one side, & the hose clips are the type else where under the bonnet that require hose clip pliers or similar to release.
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #9 on: 30 July 2008, 23:13:11 »
well thanks for that ill have to look for a new one now see if i can get one cheap
Now got 2.5 to Opel
