Author Topic: ABS & TC Lights  (Read 1549 times)
mhwest
ABS & TC Lights
« on: 29 July 2008, 17:51:48 »
On my 96 Omega CDX abs & tc lights came on after 3min run now stays on permanent all the time no other probs any where else, speedo works fine had to travel down to liverpool airport twice with lights on now able to sort out, any idea where abs relay is located.
Have been busy lately on a Vaux Cav cdx got rid when sorted also broadband went bust had to relocate so been of forum for a bit, Omega has been problem free untill now a small one I hope. :-/
Mel
Re: ABS & TC Lights
« Reply #1 on: 29 July 2008, 19:31:25 »
ideally need a code reader on it...
Re: ABS & TC Lights
« Reply #2 on: 30 July 2008, 09:30:45 »
ABS ECU?
sev
Re: ABS & TC Lights
« Reply #3 on: 30 July 2008, 20:06:23 »
I have exactly the same issue, am looking into restoring the brake system once the service is dome and out of the way.
The first thing i'm going to do before checking the ecu itself is make sure all the wheel speed sensors are clean and their hall sensor pick ups are clean, if still no joy, off to the boy for a diagnostic (will do irrespective), and then if it is the ecu, BBAREMAN it is!
1995 2.5 V6 CDX Saloon
mhwest
Re: ABS & TC Lights
« Reply #4 on: 30 July 2008, 20:21:09 »
If its ECU and a second hand one is replaced of the same GM No and model does this need to be reset by a diagnostic machine as I do not use Vauxhall but wuld use a tune up garage
Re: ABS & TC Lights
« Reply #5 on: 30 July 2008, 20:57:20 »
ABS ECU?
possible, but less likely on the pre 98 ecus
mhwest
Re: ABS & TC Lights
« Reply #6 on: 30 July 2008, 21:41:54 »
Just rememberd had a cheap Tech 2 will this read codes for ABS if I can still find it
Re: ABS & TC Lights
« Reply #7 on: 30 July 2008, 21:46:59 »
possibly
mhwest
Re: ABS & TC Lights
« Reply #8 on: 30 July 2008, 23:39:29 »
Thanks :ybeen looking further back at sites in case of renewal of ABS which has been very helpful ;)
Page created in 0.024 seconds with 16 queries.
