Author Topic: Pic of the self leverling sensor  (Read 1419 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 31 July 2008, 10:00:20 »
Hi
Can anyone help i am looking for a pic of the Self leverling sensor on the rear arm of the elite. Just need to check some details on it and hard to get a good look at it with out the car  been on a ramp.
Thanks
Steve.
hotel21
  • The Kingdom of Fife
Re: Pic of the self leverling sensor
« Reply #1 on: 31 July 2008, 10:36:10 »
Looking for one at the moment....   :y
SP_3.2
  • Leicester
« Reply #2 on: 31 July 2008, 10:45:04 »
Thank you... just need to check as i was having a word with Tony at WiM and told me that there sould be 2 screw that can be ajusted to lower the arm which would help the car sit a little lower as i have had a set of MV6 springs fitted . Just need to see where the screw are on the sensor.
Thanks
hotel21
« Reply #3 on: 31 July 2008, 10:53:48 »
In that case, the adjuster is the link rod itself.  Its a mini balljointed arm with a locknut on it, a couple of inches long.  Release the locknut and adjust the rod to suit.
Cant find a file picture but its the same as the sensors on the FNS and RNS suspension arms for the headlights.    :y
SP_3.2
  • Leicester
« Reply #4 on: 31 July 2008, 11:00:11 »
Great thanks for that will have a check at lunch time :y
SP_3.2
  • Leicester
« Reply #5 on: 31 July 2008, 11:12:52 »
Would anyone know which way i would need to ajust to make the car sit lower ie longer on shorter and by how much
Thanks
Steve.
« Reply #6 on: 31 July 2008, 15:59:30 »
any good? :-/
« Last Edit: 31 July 2008, 16:02:26 by chrisgixer »
SP_3.2
  • Leicester
« Reply #7 on: 31 July 2008, 17:00:38 »
Thats great thanks . I have had a look and could not see a way of ajusting it. There is no way to rejust the rod. :-[
« Last Edit: 31 July 2008, 17:01:02 by SP_3.2 »
Ironingboard
  • Edinburgh
« Reply #8 on: 31 July 2008, 20:19:51 »
any good? :-/
Just for info the picture shows 2 sensors, the one in the center of the picture near the differential is to do with the shock absorber leveling fitted to elites with air adjustable rear shocks.
The other HID level sensor is visible in the bottom left of the picture.
Neither are adjustable, but I've heard that your rear lowering can be altered using a tech 2, but I guess their assuming that you've already fitted lowered shocks like those for the MV6.
