Author Topic: 2.5TD WARM-START PROBLEM  (Read 1414 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« on: 31 July 2008, 10:28:00 »
My tractor has difficulty starting when warm.
It turns over for a minute or two, then a cloud of black smoke before starting.
New injection pump and no.4 injector, new fuel filter, new glow-plugs, and in-tank pump/swirl-chamber/tank clinically cleaned.
Starts on the button when cold.
No EML light showing.
No glow-plug light showing when engine is warm either.
Any pointers chaps?
It runs fine otherwise.
Re: 2.5TD WARM-START PROBLEM
« Reply #1 on: 31 July 2008, 16:43:12 »
Any codes stored?
« Reply #2 on: 31 July 2008, 19:32:01 »
not sure tbh...  ...duff cts?
Omegatoy
  • UK
« Reply #3 on: 31 July 2008, 21:31:12 »
its a well known problem, bmw in thier wisdom decided to not allow the glow plugs to come on when the engine was" warm"  many range rover owners go to ridiculous lengths to effect a cure with seperate relays and resistor etc etc, no need to do that just chip it and it solves the problem!!! :y
p.s i think ts the fuel temperature sensor where the glw plugs take the feed from to determine whether or not the engine wants heat, try pouring cold water overthe pump before you next hot start it and see if it makes a difference!!
« Last Edit: 31 July 2008, 21:32:58 by Omegatoy »
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #4 on: 31 July 2008, 22:53:47 »
As Omegatoy says, a chip might be a good idea - apparently will make its cost back in fuel economy by other accounts i've seen on here.  As you have a manual, then no problems with the marginal auto box..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Seth
« Reply #5 on: 01 August 2008, 12:07:22 »
Fuel temp sensor (where the glow-plugs take feed from) ...
Anyone know where it's located?
« Reply #6 on: 01 August 2008, 12:37:26 »
I think its on fuel filter, though I've heard Omegatoy say its in injection pump.
« Last Edit: 01 August 2008, 12:39:25 by TheBoy »
dieseldean
  • chesterfield
« Reply #7 on: 01 August 2008, 22:32:50 »
had this problem on mine about 2 year ago.
 is your starter motor tired?
 when you start from cold the exhaust brake is shut for some complicated pressure reason. but when the sensor says its warm then it doesn't bother with glow plugs or exhaust brake and this requires faster turning of starter motor than a cold start.
a tired starter motor may still have power to turn a heavy loaded cold engine but may no longer have speed to turn a warm one.
