Author Topic: camsenor light on (car off road)  (Read 1140 times)
fred117
« on: 01 August 2008, 16:27:36 »
hi still had no joy in getting the problem sorted try everything
eg change senors
diagnose test
change wire to brain and yet the light still stay on
does any one know how to fix my problem
please help
2.0 omega 1998 gls
« Last Edit: 01 August 2008, 17:31:29 by fred117 »
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
Re: camsenor light on (car off road)
« Reply #1 on: 01 August 2008, 17:05:20 »
I believe the forums crystal ball is off line at the moment, you might get a better response if you tell us what car/engine it is :-)
fred117
« Reply #2 on: 01 August 2008, 19:22:53 »
thnks added make model and year
rickyboy
  • Glasgow
« Reply #3 on: 01 August 2008, 21:36:56 »
If the sensor has just been changed and the light remains on try turning the ignition on to position 2 (without starting the engine) and wait until the abs and srs lights go out.  Turn off again.  Repeat this 25 times.
If the light still does not go out.  Do the paperclip test again and post all the results.  Paperclip test guide is in the link below...
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #4 on: 01 August 2008, 21:39:28 »
Even if you have changed a sensor, the fault will still be logged for something like 25 "good" starts of the enigne.
If it still doesn't start after changing the sensor (and that was the only fault code), then i'd suggest that your sensor might be duff...or is it actually got no fuel?  That didn't actually show a fault code when my (non factory) immobiliser prevented the fuel pump from running..
Cam sensor shouldn't stop a 2.0 from running, though..just flag a fault.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
markey mark
  • SLady bitshorpe north lincs
« Reply #5 on: 02 August 2008, 00:24:57 »
very good weds  ;D ;D
Page created in 0.024 seconds with 16 queries.
