Author Topic: Blown a Hose or HG gone?  (Read 3527 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
« on: 03 August 2008, 12:35:56 »
Was out on a mission yesterday and just after a kickdown overtake i noticed 'coolant level' on the MID, pulled into destination a min later to find steam pouring from the bonnet :o
Popped the bonnet to find the water hose between rh side of block and top of rad had blown a big f.o. hole :-/
luckily there was a building site next door and a really helpful Polish guy got me some duct tape and a bucket of water so i could limp home.
He said to me that it might be HG pressurising the coolant system (he was very switched on) but there have been no signs so far and i've run through the (http://www.omegaowners.com/forum/YaBB.pl?num=1209123016 ) flow chart and i'm not convinced.
Anyone else had trouble with this hose (split on short run from block just before bend up) i guess they can just split with fatigue (11 years old)?
And where's the best place to get a NEW replacement i cant find them on the AutoVaux site?
thanks in advance :y
trebor
  • Swindon
Re: Blown a Hose or HG gone?
« Reply #1 on: 03 August 2008, 12:52:37 »
MIne split after the head gasket went.
I got a replacement from Vauxhall, on the TC card it wasn't too expensive.  I'll try and find receipt.
« Reply #2 on: 03 August 2008, 13:25:42 »
Replace the hose, run up to temperature removing all airlocks - and monitor carefully for excess pressure.
Also look for signs of fuel smell in header tank etc.
« Reply #3 on: 03 August 2008, 13:45:19 »
v6 HGs virtually never fail like that, so replace hose and see what happens...
HerefordElite
  • Hereford
« Reply #4 on: 03 August 2008, 13:59:29 »
i thought as much but just wanted to get a few opinions :y
ps hose part no is GM90572935
« Reply #5 on: 03 August 2008, 14:00:43 »
is it poss its had oil spilt on it from a fill up, or similar and its
Eaten the rubber over time?
trebor
  • Swindon
« Reply #6 on: 03 August 2008, 14:00:49 »
I think mine went after the head gasket failed.
HerefordElite
  • Hereford
« Reply #7 on: 03 August 2008, 14:02:53 »
it is directly below the filler if oil can do that?
HerefordElite
  • Hereford
« Reply #8 on: 03 August 2008, 14:16:57 »
another question -
hose is fitted with standard awkward to remove squeeze together clips, any objections to refitting with a good old jubilee clip? ::)
« Reply #9 on: 03 August 2008, 14:19:06 »
another question -
Yes. Keep to std clips.
The spring clips, as well as allowing quicker production, also allow expansion/contraction with heat, always being at the right tension.  Jubilee clips do not allow this.
« Reply #10 on: 03 August 2008, 14:21:06 »
Depends on the rubber. Obviously oil seals are
designed to seal oil so not in that case, but are the water
hoses Designed to deal with oil? Suspect not?
HerefordElite
  • Hereford
« Reply #11 on: 03 August 2008, 14:21:18 »
another question -
exactly why i asked - cheers TB :y
Big_Roger
  • Southampton
« Reply #12 on: 03 August 2008, 14:28:07 »
Hi,
I think it likely your hose failed with all the previous twisting and pulling to get it off the transfer pipe if at any time there has been a thermostat replacement.
Other than that just sods law.
With regard to hose clip replacement with a jubilee type clip.
As it is tightening onto a metal pipe, I see no problem. I used a jubilee clip on mine.
It is when the hose pillar you are fitting the hose to is made of plastic, ie radiator and HBV connections etc, that jubilee clips are a NO NO
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
trebor
  • Swindon
« Reply #13 on: 03 August 2008, 14:55:03 »
Retail was £16.90 + VAT.
I paid £11.04 + VAT
« Reply #14 on: 03 August 2008, 18:00:41 »
saw an oil breather pipe on a 99 2.0 4pot the other
Day. More like plastercine than rubber.
