Author Topic: Air Con Question  (Read 921 times)
Big_Al
Air Con Question
« on: 06 August 2008, 21:43:05 »
My 3.0 seems to run a few degrees hotter with AC on . Up to about 97- is this normal or do i start looking at a system descale & flush etc.
Regards, Big Al   :y
Mike Collins
  • North of Bristol
Re: Air Con Question
« Reply #1 on: 06 August 2008, 22:07:16 »
Interesting, they normally run hotter with it off, ie eco button pushed, the front fans don't run then. It is climate control?
Are both your auxiliary fans running all the time with compressor clutched in?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 06 August 2008, 22:10:08 »
I to find my 3.0 runs slightly warmer with the air-con on too...
Also if i have the heaters on warm it runs cooler than if heaters are on cold :D
Big_Al
« Reply #3 on: 06 August 2008, 22:21:13 »
Hi Mike,
Yes my system is Climate Control- but -
Not too sure what I'm doing with the AC.  I just press "Auto & turn temp down to "LO" & it gets all blowey &  nice & cold.
The two fans behind grill run when AC is on.
Not sure what "ECO" switch does though.  :-[ :-[ Any chance you could describe what I should be doing in using the AC.
Regards Al   :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #4 on: 06 August 2008, 22:44:39 »
Hi Mike,
Regards Al   :y
I set the temp to about 68-70 and let the climate maintain that temp within the car. If you set it on low it will just keep blowing at max fan speed forever :y
Trade club card holder
Code scanner available
