Author Topic: need help car not starting  (Read 3889 times)
johnnycboy
  • Colchester
Re: need help car not starting
« Reply #15 on: 05 August 2008, 10:12:46 »
As far as i'm aware there are two types of connector (someone may be along in the minute and say different), check at the back of the engine under the scuttle and look at the connector - it will either be a oval or square.  oval one seems to be cheaper.  do you have tc card - if not i can assist. :y
rikki_essex
  • essex
    • 2L gls estate with lpg 20
« Reply #16 on: 05 August 2008, 11:47:59 »
just to let you know ive just ordered the part from vauxhall parts i found them on ebay. they just got me a deal for £30.54 plus £3.95 p&p plus the local garage will fit it for £20. but i did ring a few other places and the most expensive one was £120 to supply and fit and he even said it might be more becuase its a v6. and the good thing is the one i just bought is genuine vauxhall so result and if any body wants the number for them it 01858 433 599
regards Rik
johnnycboy
  • Colchester
« Reply #17 on: 05 August 2008, 12:03:55 »
save yourself £20 quid and do it yourself.  1/2 hour - hour :y  plus you know its done properly then.
rikki_essex
  • essex
« Reply #18 on: 05 August 2008, 12:43:06 »
lol thats the problem im not the most mechanically minded and ive got to pick the misses mum and dad up from the airport sat night and god help if it went then.
regards Rik
johnnycboy
  • Colchester
« Reply #19 on: 05 August 2008, 12:47:55 »
rikki_essex
  • essex
« Reply #20 on: 07 August 2008, 14:48:49 »
right just had the crank sensor changed it was the right part thankfully and it was only £30 quid. just one more question is the fault 0335 stored on the system because i just done the paperclip test again and its still showing the fault.
regards Rik
rikki_essex
  • essex
« Reply #21 on: 07 August 2008, 15:29:03 »
regards Rik
Grumpy
  • Manchester
« Reply #22 on: 07 August 2008, 15:44:07 »
It will stay stored for 'X' number of clean starts.
I say 'X' because some folk say 20 starts and others differ.
Mine took 2 months  :(  before it cleared from memory, even though
the fault was cleared and no EML light on.
If you don't get the problem and the EML stays off, don't worry about it.
« Last Edit: 07 August 2008, 15:44:45 by Grumpy »
