Author Topic: need help car not starting  (Read 3868 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
« on: 04 August 2008, 12:34:24 »
just wondered if any one could shed some light on my little promblem. a couple of weeks ago my car was parked on a slight incline with the front end pointing  down the hill and i had some trouble starting it there was still about a 1/4 of a tank of juice. and then again on friday night when the misses decided that it would be a good idea to stop for a kebab on the way home. and again it was parked on a incline and wouldnt start at all. so i pushed the car into a space a got a taxi home and when i went back in the morning it was fine and started first time. any ideas????
regards Rik
Re: need help car not starting
« Reply #1 on: 04 August 2008, 12:41:14 »
Check for stored fault codes, wondering if there is a 0335 in there somewhere....
« Reply #2 on: 04 August 2008, 12:52:12 »
To read the stored engine mgmt codes on a 2.6, check out the thread 'Paperclip Test' in Maintenence Guides, but rather than use paperclip, press both brake and accelerator, and turn ign on.
rikki_essex
  • essex
« Reply #3 on: 04 August 2008, 13:42:05 »
right just done this and how do you make sense off the flashes
regards Rik
rickyboy
  • Glasgow
« Reply #4 on: 04 August 2008, 13:46:41 »
Count the number of flashes.  There will be a pause between each sequence of flashes.
For example if it flashes 10 times, then a pause, then 3 times, pause, 3 times, pause, 5 times pause your code would be 0335.  Count 10 flashes as a zero.
Report back the codes.
rikki_essex
  • essex
« Reply #5 on: 04 August 2008, 16:04:18 »
just done that test and the code was 0335 so what does that mean?
regards Rik
rickyboy
  • Glasgow
« Reply #6 on: 04 August 2008, 16:08:07 »
As first thought.  Crank sensor needs changing.  Only buy a genuine Vauxhall part.
rikki_essex
  • essex
« Reply #7 on: 04 August 2008, 16:12:54 »
i just read how to change it is it that simple or is it worth putting it into the garage and do you know how much the crank sensor costs.
regards Rik
« Reply #8 on: 04 August 2008, 16:51:34 »
£37 + VAT trade.
Use the guide in Maintenence guides, take about 30m - 1hr.
johnnycboy
  • Colchester
« Reply #9 on: 04 August 2008, 16:52:13 »
where abouts in essex are you,  price varies on the type you have, easy enough to fit 1/2 hour.  can help if you are local to me :y
rikki_essex
  • essex
« Reply #10 on: 05 August 2008, 07:14:03 »
THANKS FOR ALL UR HELP ILL TRY TO DO IT ON THE WEEKEND. WHAT DOESTHIS CRANK SENSOR O THEN WHY DOES IT ONLY DO IT ON A HILL JUST OUT OF INTEREST REGARDS RIKKI
regards Rik
johnnycboy
  • Colchester
« Reply #11 on: 05 August 2008, 07:50:24 »
Its giving you a warning that it will eventually fail when you least expect it.  Its no fun when it completely gives up the ghost.
rikki_essex
  • essex
« Reply #12 on: 05 August 2008, 09:43:44 »
sorry to be a pain to all of you i dont suppose any one would know the part number for mine as i keep getting asked for it as know one seems to know what one i need.
regards Rik
« Reply #13 on: 05 August 2008, 10:04:45 »
go to vauxhall, give them the reg. Or chasis no. if they
need it. Get a price, they will print it out on an invoice
To be paid. It will have the no. on there. If you must,
you can shop around but i would just get it done
asap if i where you.
Or just ring them.
« Last Edit: 05 August 2008, 10:05:56 by chrisgixer »
« Reply #14 on: 05 August 2008, 10:09:45 »
When I did mine there was only a few quid in it between the genuine part from a VX dealer on TC and the cheapest on Ebay. Given the risk of it stranding you I'd just get one from the stealers.
