Author Topic: Pulling things.....  (Read 915 times)
eastwood
  • North East
Pulling things.....
« on: 07 August 2008, 16:46:26 »
I have  large...er very large twin wheel caravan, Ive checked the weights and Ill be ok with that but I need a tow bar, any suggestions about where to get the best deal on one?
Any fitting tips???
cheers
all
Stuart
Re: Pulling things.....
« Reply #1 on: 07 August 2008, 16:55:46 »
Cheapest way is to have a search on Ebay. Can't do much better than this for a spanking new one:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380052544820
I've had one of these and it turned up quick, was straightforward to fit, etc. Of have a look in the "For Sale" section for a second hand one.
You can get prettier swan-neck and removable ones. be aware that some require a plate to be bolted to the boot floor which can be a pain. The above one doesn't.
Plenty of info here about wiring up the electrics if you do a search.
Fitting tip: If you find you need to remove the tar-like material from the boot floor, softening it with a hot air paint stripper when scraping it off with a chisel is the way.
« Reply #2 on: 07 August 2008, 16:57:07 »
Should say the information above relates to the saloon towbar. Estates are radically different.
Page created in 0.091 seconds with 16 queries.
