Author Topic: fault code/heater flap  (Read 1793 times)
tafcol
  • St Athan, Barry, Wales
« on: 07 August 2008, 12:12:06 »
Hi all been a while since i've been on hope everyone alright. Just brought up a strange fault code on my omega 2.5 V6 year 2000 via the paper clip method the car is giving out a fault code of "89" has anyone come across this before as my autodata doesn't recognise it.
Also has any one ever heared of a heater problem which stops you going from hot to cold. something about a solonid driven flap that un clips itself stopping you geting hot or cold air into the cab. Any ideas most welcome.
Re: fault code/heater flap
« Reply #1 on: 07 August 2008, 12:26:08 »
Moved...
Grumpy
  • Manchester
« Reply #2 on: 07 August 2008, 12:33:18 »
http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
Don't know about your code 89, but thr above link might be useful
for your heater problem.
rickyboy
  • Glasgow
« Reply #3 on: 07 August 2008, 15:09:50 »
89 is O2 sensor.  Any holes in the exhaust?
tafcol
« Reply #4 on: 07 August 2008, 15:24:28 »
no holes in the exhaust but just completed a head gasket change 3 months ago may have desturbed it some how many thanks for advice
rickyboy
  • Glasgow
« Reply #5 on: 07 August 2008, 17:07:24 »
I don't know the location of the wiring for the o2 sensor but it may be possible you've nipped a wire.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 07 August 2008, 17:43:39 »
on v6 if its a 2.5/3.0 it has 2. one on each downpipe
if its 2.6/3.2 it has 4 same as 3.0 then 1 on each pipe after the cat
« Last Edit: 07 August 2008, 17:44:06 by tmx »
Page created in 0.477 seconds with 16 queries.
