Author Topic: Turning Up 2.5V6 Idle.  (Read 2037 times)
chuck_g
  • Cork, Ireland
« on: 06 August 2008, 17:24:56 »
As the tiltle says lads im just wondering hows to turn up the idle on my 2.5. Afaik she should be idling on 8-900rpm, am i right?? Shes on about 5-600 at the moment. Thanks all
O.M.E.G.A -Opel make extra great automobiles
http://www.chucklez84.bebo.com
Re: Turning Up 2.5V6 Idle.
« Reply #1 on: 06 August 2008, 17:27:56 »
500-600 is correct for V6.
chuck_g
  • Cork, Ireland
« Reply #2 on: 06 August 2008, 17:33:10 »
Seems very low!!! But il believe ya :) Whats annoying me tho is because its so low the exhaust is rattling a bit!!! Would it be stupid to turn it up a touch??
Mike Collins
  • North of Bristol
« Reply #3 on: 06 August 2008, 17:39:09 »
Yes,,,,, there is no adjustment, the idle is controlled by the ECU via the idle control valve. Maladjusting the throttle stop is a bad idea.
The idle speed should increas slightly as the a/c compressor clutches in and you should be able to hear it compensate for heavy electrical loads.
chuck_g
  • Cork, Ireland
« Reply #4 on: 06 August 2008, 17:42:21 »
Okay thanks buddy!! I took out the a/c for better performance!!
ians
  • Reading
« Reply #5 on: 06 August 2008, 18:35:12 »
Sorry - but it needs saying that the exhaust is rattling because its either loose or falling apart (maybe baffles) - it shouldn't normally rattle.  So best to fix that :y
check all the rubber bits are in place and that its not rattling against the body (rear heatshield can come adrift and rattle against the top of the back box.)
jonathanh
  • coventry
« Reply #6 on: 06 August 2008, 18:43:53 »
as can the outer casing on the cat pipes - I think they can be jubilee clipped to get them tighter.
and 5-600 for a 2.5 V6 is spot on - mines always idled there
« Last Edit: 06 August 2008, 18:44:31 by jonathanh »
chuck_g
  • Cork, Ireland
« Reply #7 on: 06 August 2008, 18:44:21 »
Kool fella il try changing the exhaust  :y
cbowditch
« Reply #8 on: 06 August 2008, 20:16:22 »
I had exactly the same problem a couple of weeks back. An annoying rattle which could only be heard at Idle. I took it to a garage and they told me baffles had gone in the exhaust back box. I had the back box changed and its been good as gold ever since   :y
« Reply #9 on: 06 August 2008, 20:48:36 »
The rattle could well be the heat shields and is easily sorted with some large jubilee clips :)
Mike Collins
  • North of Bristol
« Reply #10 on: 06 August 2008, 22:11:12 »
I can't imagine you will notice a difference in performance with a/c off. There should be a full power a/c disable in the ecu.
Loss of comfort certainly.
chuck_g
  • Cork, Ireland
« Reply #11 on: 06 August 2008, 22:26:47 »
Well firstly a/c drinks petrol ans at the price these days i cant afford it!! Secondly a/c would be an extra pulley therefore draining more power!! Shes alot more responsive since i took it out!!
I checked the exhaust its the baffles....cheers lads
Mike Collins
  • North of Bristol
« Reply #12 on: 07 August 2008, 08:56:59 »
I can't see a significant difference in fuel consumption display on my 2.6 with a/c on or off.
Theoretical difference maybe but driving with the windows open for cooling increases drag and again, in theory, consumption.
With much older systems I can remember feeling the power loss when the compressor engages.
I'll stick to quiet comfort.
« Reply #13 on: 07 August 2008, 08:59:24 »
AC has a heavy drain on power when on, but when off, all it does is freewheel a pulley and carry the extra few kgs around.  I wouldn't remove it for performance...
Mike_T
  • Trimley Nr Felixstowe
« Reply #14 on: 07 August 2008, 21:59:25 »
If you want to save fuel then why on earth would you want to increase the idle speed ?? I travel with the climate control on nearly all the time and get an average fuel return of about 23 - 24mpg travelling to and from work about 12 miles and on a long run cruising around the 80s anything up to 31mpg. This engine is more than capable of powering everything fitted and then some.
With your aircon dissabled you will have no de-humidifyer  :o I wonder how you are going to get your windows demisted in the bad weather  ::)
Mike.
