Author Topic: 2.2 HBV replacement  (Read 1636 times)
Shaman61
  • Lincolnshire
2.2 HBV replacement
« on: 02 May 2008, 12:45:33 »
Anyone got any tips for changing the HBV on a 2.2 or even a tip for a decent tool for one handed removal of hose clips, it looks a right idiot of a job.
Re: 2.2 HBV replacement
« Reply #1 on: 02 May 2008, 12:47:11 »
Mole grips work well, as do hose clip removal pliers you can get for a few quid in Halfords.
Never done it on a 2.2 though sorry
ians
  • Reading
« Reply #2 on: 02 May 2008, 12:55:53 »
correct ;)
tools should include plasters and a swearbox..
seriously i recommend a small set of molegrips - much more useful investment than specialist host clip pliers.
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 03 May 2008, 14:51:26 »
Seem to remember that you can get to it from underneath if on a lift or ramps, still awkward though.
One pair of hands from above and another from below??
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 03 May 2008, 21:10:28 »
it is a right idiot of a job but is doable if you remove wipers and scuttle from top or if you have small hands and arms then try fron underneath !! :y
adi
« Reply #5 on: 08 August 2008, 12:32:27 »
I just replaced mine...main dealer wanted £170 + parts... got the part for about £30 & fitted it in about half an hour...  Take the 2 hoses on one side off first then pull up &  take the single hose off...used plumbers grips...  Only thing is my heaters not blowin hot so looks like it needs bleeding...
« Reply #6 on: 08 August 2008, 12:33:58 »
Bit easier on 2.2, but even on v6 not a bad job :y
adi
« Reply #7 on: 08 August 2008, 12:43:10 »
Any idea why the heater might not be blowing hot?...
« Reply #8 on: 08 August 2008, 12:45:13 »
Either airlock, as suspected, or a constant vac to the hbv...
« Reply #9 on: 08 August 2008, 12:47:25 »
I'm not so sure - on the 2.2 (and my 2.0, that you'll remember me doing) you have to get it from underneith, which means a soaking ;D
V6 it is mounted higher up and I can get my hands in there with the scuttle off...
Out of preference, I'd rather do a V6 ;D
