Author Topic: White ECO Button  (Read 1595 times)
Mike_T
  • Trimley Nr Felixstowe
White ECO Button
« on: 07 August 2008, 21:34:15 »
The black has come off my ECO button and the dealer says its part of the whole heating system control panel costing £535 + VAT  :( . Is there a way of replacing this button if I could get one from a breakers ??
Cheers Mike.
MutantCav
  • Gainsborough
Re: White ECO Button
« Reply #1 on: 07 August 2008, 21:37:27 »
I find it really hard to believe the facelift Omegas are THAT different...pre 2000 the eco button simply unplugs from the dashboard with the help of a small flat bladed screwdriver and you simply popin a replacement...surely the facelift cant be any different???
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 07 August 2008, 21:39:06 »
Two of the bulbs on mine dont work and the dealer told me the same kinda story .... whole thing needs replaced  :-/
« Reply #3 on: 07 August 2008, 21:49:54 »
Cheers Mike.
Thats right  :'(
Ironingboard
  • Edinburgh
« Reply #4 on: 07 August 2008, 22:40:06 »
Cheers Mike.
Yip I heard the same thing, tried to source some from Siemens who make the control module for the Omega climate control. The rubber buttons are not a separate item according to VX, but if you look at the VX EPC for the face lift climate control, it gives a Siemens part number for the rubber buttons.
 You can try to contact Siemens directly or you might try RS to order a Siemens part for you. Worth a try, always play the environment card and say that your trying to reduce electronic waste  ;) etc.
Best of luck and let us know how you get along.
« Reply #5 on: 08 August 2008, 08:05:23 »
Failing that the panels pop up on ebay now and again...replace the whole lot.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Trade club card holder
Code scanner available
MutantCav
  • Gainsborough
« Reply #7 on: 08 August 2008, 08:17:35 »
Wow seems rather a negative way to go to have to replace the entire unit cos a bulb has blown or the button peeled...good ol' Vaux! :)
« Reply #8 on: 08 August 2008, 08:19:53 »
It's the future, and must be progress  ::)
Mike_T
« Reply #9 on: 09 August 2008, 20:45:34 »
Thank you all for your help and advice  :y I will try your sujestions.
Mike
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #10 on: 11 August 2008, 07:06:22 »
There was a climate panel in a scrapper at Car Transplants in Nantwich Cheshire only last week...  no eco button though, as that is a seperate item!!!!
Google 'em, contact them, they'll mail order it if still any good...
DC
