Author Topic: oil cooler unions  (Read 1079 times)
oil cooler unions
« on: 11 August 2008, 15:26:56 »
Hi Guys,
What is the PN for the washers that sit below and above the oil cooler pipes (to cooler). Also, is there one for the bolts that hold them in? (Are they the same as coolant bridge bolts? ::)  )
Cheers
J
Dazzler
  • Haverhill, Suffolk
Re: oil cooler unions
« Reply #1 on: 11 August 2008, 15:35:25 »
They are not the same as the coolant bridge bolts......the banjo holes are in a slightly different position.
Dazzler
« Reply #2 on: 11 August 2008, 15:36:30 »
Its all in this guide James, with pics and p/n's ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1211220529
« Reply #3 on: 11 August 2008, 17:25:19 »
Your local friendly dealer can give you the PNs as well ;)
« Reply #4 on: 11 August 2008, 19:47:52 »
Shaddap you ;D
