Author Topic: Parts needed for top end rebuild  (Read 1969 times)
« on: 11 August 2008, 19:58:50 »
Head gaskets x 2
Stem seals x 24
Coolant bridge doughty washers x 4
Oil cooler kit (Do VX sell a "kit" or do I have to ask for the parts on their own?)
Genuine Exhaust gaskets x 2
Genuine exhaust downpipe rings x2
Camcover seal kit (shop?)
Plugs x 2 (I already have 4)
Have oil
Coolant x 5l
Oil filter
Rear transfer pipe seal
Thermostat, thermostat O ring, transfer pipe O rings. (Want to change stat, as it's running too cool.)
Grey Goo
Green goo
Any rough idea on what this little lot will set me back?  :-[
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Parts needed for top end rebuild
« Reply #1 on: 11 August 2008, 20:01:51 »
Head gaskets x 2
Stem seals x 24
Have oil
Coolant x 5l
Oil filter
Grey Goo
Green goo
Don't forget to add black goo and new stretch bolts
TuBy's new whipping boy.
« Reply #2 on: 11 August 2008, 20:04:50 »
Of course, bolts...
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #3 on: 11 August 2008, 20:07:41 »
vx dont do an oil cooler kit, but everything you need is here (including part numbers)
http://www.omegaowners.com/forum/YaBB.pl?num=1211220529
PM with your requests.
hotel21
  • The Kingdom of Fife
« Reply #4 on: 11 August 2008, 20:14:06 »
I still think you should go fishing first, then start the fekker if all else fails....
« Reply #5 on: 11 August 2008, 20:16:13 »
I will definately go fishing, this is if all else fails....
« Reply #6 on: 11 August 2008, 22:05:50 »
you have done enough of the V6 HG's to know the cost by now!
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 12 August 2008, 00:16:08 »
Add a spare T55 bit, they only last for a few heads then explode.
PM Mark about head bolts, we had some crap ones recently with distorted threads and others that snapped after the first 90 deg  :o, think we used FAI in the end but he should remember
« Reply #8 on: 12 August 2008, 00:21:33 »
Yes, but never one with all genuine parts ;)
