Author Topic: Helicoil  (Read 3661 times)
osealy
  • dublin
Re: Helicoil
« Reply #15 on: 12 August 2008, 18:50:29 »
I also lost a drain plug on a yump.
Now I just use Pela pump out. It sucks out the oil while I change the filter. No need to go under car at all.
Re: Helicoil
« Reply #16 on: 12 August 2008, 19:16:49 »
It does it good to drain, esp as the BMW diesel sufferes from the 'black death' to reduce the sludge build up.... ....actually, wonder if that is contributing to your overheating  :-/
dieseldean
  • chesterfield
Re: Helicoil
« Reply #17 on: 12 August 2008, 20:29:44 »
With the endless sump stripping my tractor suffered (across 2 engines), I can only say that helicoil was the solution.  And the helicoil held together when when I lost the 'quickdrain' sump plug when I bottomed it out at 80mpg.
put your plastic sumpguard back on it. you also get better airflow to radiator.
dieseldean
  • chesterfield
Re: Helicoil
« Reply #18 on: 12 August 2008, 20:35:30 »
my now retired 1994 2.5td has had a helicoil fitted for 9 years it has done 351000 miles and had oil changed every 3000-3500miles dont know what mileage was when helicoil fitted as it was dad's car back then
Re: Helicoil
« Reply #19 on: 12 August 2008, 20:37:34 »
No cooling issues with mine ;)
The quickdrain I had hung down about an inch lower than sump - it was only a matter of time ::)
Re: Helicoil
« Reply #20 on: 12 August 2008, 21:02:01 »
Still amazed it actually got you home!
Re: Helicoil
« Reply #21 on: 12 August 2008, 21:03:38 »
From Mark's?  Dual carriageway/motorway all the way, so no chance of catching it there....
Re: Helicoil
« Reply #22 on: 12 August 2008, 21:04:47 »
The lanes near your house are enough surely!  all thos little roundabouts  ;D
Re: Helicoil
« Reply #23 on: 12 August 2008, 21:05:43 »
Actually, drove passed the layby, can still see the oil slick...   :-[
osealy
  • dublin
Re: Helicoil
« Reply #24 on: 12 August 2008, 22:00:43 »
You may well be right!! But with the fans running ,the top of the rad is cold to touch. Bottom is hot. I left the vicous off, I dont think it was working.. I guess I may have to get another rad to try , but I'm not looking forward to tampering with the tranny cooler.
Re: Helicoil
« Reply #25 on: 12 August 2008, 22:35:43 »
ATF cooler is not a problem to be honest, just get some replacement copper washers, which should prevent leaks once done.
You'll probably lose a cupful or 2 of atf, so need to redo level afterwards...
