Author Topic: Help for a man with two left hands  (Read 2335 times)
Crazydad
  • Germany
    • 2.5 V6 facelift
« on: 29 October 2007, 19:44:40 »
who can tell me what this is called??
as i have to fit a new one to my car :-/
miggy
Re: Help for a man with two left hands
« Reply #1 on: 29 October 2007, 19:46:17 »
Ball joint innit
miggy
« Reply #2 on: 29 October 2007, 19:47:30 »
Drill out the old studs and replace with nuts/bolts
 :y :y
« Reply #3 on: 29 October 2007, 19:48:03 »
I'd be personally doing the whole suspension arm(s)
miggy
« Reply #4 on: 29 October 2007, 19:49:52 »
There cheap enough
 :y :y :y
Taxi_Driver
« Reply #5 on: 29 October 2007, 19:50:50 »
Thats easy....its called a thingy  :y ;D
miggy
« Reply #6 on: 29 October 2007, 19:52:19 »
No its a foo foo joint
 ;D
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #7 on: 29 October 2007, 19:55:07 »
your not making it easy for me   :o :(
ok James can you give me more Info??
miggy
« Reply #8 on: 29 October 2007, 19:58:27 »
Seriousley mate, i am sure it is a bottom ball joint, you can buy these or you can get the whole suspension arm as mentioned, I am sure jamie will point you in the right direction.
Tap it in on ebay and you will see the whole thing.
 :y :y :y
« Reply #9 on: 29 October 2007, 19:58:47 »
If I'm not wrong crazydad, that is the lower suspension arm (wishbone) bottom ball joint
OE ones were rivetted onto the wishbone, so if you were to change just the balljoint on it's own, you would need to drill the old rivets.
Wishbones are only about £25 each, with the balljoint already attached, so I'd be doing the wishbones..
miggy
« Reply #10 on: 29 October 2007, 20:00:19 »
 :y :y :y
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-FRONT-2-WISHBONE-ARM-BALL-JOINT-BUSHES_W0QQitemZ280167331847QQihZ018QQcategoryZ10404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the things on the ends
 :y :y
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #11 on: 29 October 2007, 20:08:14 »
i Raise my hat to you both :-[
Thank you very much for the advice, i think that you are both right, in  the fact that it is better to fit new
wishbones.
Thanks James :y
Thanks for the Link pete :y
miggy
« Reply #12 on: 29 October 2007, 20:13:12 »
wishbones.
Thanks James :y
No probs mate
Danny
  • Wigan, Greater Manchester
« Reply #13 on: 29 October 2007, 20:50:02 »
you're all wrong, its called a " PAW PRINT " ;D
« Last Edit: 29 October 2007, 20:50:43 by D4NNY »
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #14 on: 29 October 2007, 20:50:42 »
;D ;D ;D
Page created in 0.038 seconds with 17 queries.
