Author Topic: timing belt  (Read 1199 times)
blootak
  • Preston
timing belt
« on: 13 August 2008, 19:10:20 »
hello my timing belt has slipped
and stuff has broken
what is likely to have bust ?
Danny
  • Wigan, Greater Manchester
Re: timing belt
« Reply #1 on: 13 August 2008, 19:30:00 »
if you're certain something's broken, you'll have bent valves :(
Re: timing belt
« Reply #2 on: 13 August 2008, 19:32:25 »
You may well have bent valves, possibly cracked the valve guides and worse case holed a piston :(
« Last Edit: 13 August 2008, 19:33:00 by Elite_Pete »
jonathanh
  • coventry
Re: timing belt
« Reply #3 on: 13 August 2008, 20:08:57 »
could be lots of bad news here BUT do not lose all hope.  It depends on how much it has slipped.  If a tooth or two then you may just get away with it.
What to do - identify why the belt has slipped first and how far it has slipped.  Second if you can reliably reset the belt then do so and check the compression on each cylinder.  If you get compression I'd throuw on a new belt and tensioner and give it a go.
MutantCav
  • Gainsborough
Re: timing belt
« Reply #4 on: 13 August 2008, 20:11:00 »
What engine do you have?
Re: timing belt
« Reply #5 on: 13 August 2008, 20:16:07 »
On a v6, if its slipped more than 3 teeth or so, valves will have had a chat with pistons....
