Author Topic: Steering idler- which ball joint separator?  (Read 1169 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 14 August 2008, 21:33:18 »
Got my new VX idler arm and tried to fit it.
Got the big end off easy enough. The little end - no way even using the secret method involving two hammers.
What type of joint separator is best to buy off Ebay.co.uk? I cannot find any of mine!
varche
Re: Steering idler- which ball joint separator?
« Reply #1 on: 14 August 2008, 22:01:10 »
I ended up getting both types :(
  • Online Online
« Reply #2 on: 14 August 2008, 22:07:10 »
I'll be needing those then  ::)
v6coop
  • Nottingham
« Reply #3 on: 14 August 2008, 22:18:11 »
Mine was really tight too. When I had the nut off I filled the gap around the top off the taperd shaft with WD-40 and left it for half an hour. Then went back to it and striking the end of the idler with a hammer (not easy as there is not much room) to shock the area around the ball joint shaft whilst applying some pressure with a lever was enough to separate it. Best to put the nut back loosely onto the ball joint to protect the thread though.
« Last Edit: 14 August 2008, 22:18:52 by jonlew5 »
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 14 August 2008, 22:19:15 »
personaly i'd use the wind up scissor type, not keen on bashing the cr4p out of a fork type tool when it comes to steering components (things tend to get bent) :y
« Reply #5 on: 14 August 2008, 23:06:34 »
..... The little end - no way even using the secret method involving two hammers.  ......
That's how I removed mine ....... in the end, knocking ten colours of sh1te out of it 'judicious tapping' ;D on the sides of the taper. It did work in the end .... I think I just wore it down!  ;D  ;D  ;D  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #6 on: 14 August 2008, 23:16:34 »
took the big end off, turned the arm round to face the inside of the car then 3 big smacks with BIG hammer, dropped off no probs.  :y
