Author Topic: Breather or vent on Differential ??  (Read 1081 times)
Big_Roger
  • Southampton
« on: 16 August 2008, 20:05:41 »
Hi,
I have just replaced the leaking pinnion oil seal on the differential unit.
I am puzzled why it should have been leaking quite so bad, and wondered if there was a small air / pressure relief vent  that is blocked.
While I was doing the job I looked as best I could, and felt around over the top of the unit, but couldn't find anything.
I know that when I had the diff off of my Senator, there was a small plastic breather/vent about the size of a 6mm bolt head on that.
Does anyone know if there is a breather/vent on the Omega diff.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Matchless
  • Nottingham
    • A white van
Re: Breather or vent on Differential ??
« Reply #1 on: 16 August 2008, 20:10:45 »
Plastic vent on top iirc.
Designed to let all the oil escape from the spare diff under the garage bench.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #2 on: 16 August 2008, 20:35:17 »
PMSL ;D ;D ;D
less
  • Hemel Hempstead
    • 2.6 auto saloon
« Reply #3 on: 16 August 2008, 21:58:06 »
 ;D ;D ;D ;D  Classic!!
« Reply #4 on: 17 August 2008, 00:39:36 »
.. and the consequential smell of cat's pee takes about a year to go. >:(
Next time I rebuild a diff I'll do it down the back of the garden. :-X
