Author Topic: air temp sender!!!  (Read 1419 times)
eastwood
  • North East
air temp sender!!!
« on: 17 August 2008, 11:19:24 »
HI All
Can some one tell me exactly where the air tem sender unit is located, bought a new thing but cant find where to plug it in!!!
2.6V6 CDX facelift!!!
help would be appreciated ta
Stuart
Re: air temp sender!!!
« Reply #1 on: 17 August 2008, 11:33:13 »
HI All
Stuart
Which one, the outside temp sensor, or intake temp sensor
« Reply #2 on: 17 August 2008, 11:33:43 »
Doh! just seen, 2.6  :-[
Its behind bumper, near the middle...
eastwood
  • North East
« Reply #3 on: 17 August 2008, 11:37:44 »
its the outside air temp that shows the figure on the digi display!!
is it easy to get at???
Stu
RichardH
  • Ireland
« Reply #4 on: 17 August 2008, 13:09:55 »
Yep, easy enough.  Just reach in behind the bumper above and below and you should be able to pop out the old one and insert the new.
« Reply #5 on: 17 August 2008, 14:13:05 »
Open the bonnet and look below the washer bottle mounted in the front bumper.....its clipped to the bottom of the bumper assembly.
eastwood
  • North East
« Reply #6 on: 18 August 2008, 08:29:34 »
Thanks all,
Found It
Changed it
Fixed It
Thanks
Stuart
