Author Topic: HBV Vacuum Pipe (where does it go??????????)  (Read 1495 times)
trademeister
  • Rotherham
« on: 08 August 2008, 00:03:01 »
 Ive replaced my HBV and the vacuum pipe came off!! I cant seen to see where it reconnects!! Any info or pics please???
Alex Wood
  • Greenhithe, Kent
Re: HBV Vacuum Pipe (where does it go??????????)
« Reply #1 on: 08 August 2008, 00:29:25 »
The vac pipe pushes onto a spout right in the middle at the top of the HBV. Should be obvious as the spout sticks up about 10 mil, unless it's snapped off?
« Reply #2 on: 08 August 2008, 01:01:33 »
I had assumed he meant the other end?
rennes
  • Tallinn, Estonia
« Reply #3 on: 08 August 2008, 07:26:50 »
The other end goes into firewall. I have the left hand steering car so in my case it's on the passenger side of the car. If you look up from passenger footewell, you'll see vacuumpipe going into firewall. The two pipes meet in the rubber connector inside firewall. It's kinda cone shaped so it will not be too hard finding it from engine room side. You have to have small arms though to reach down there :D Flashlight will help you. Just reach down there and push the damn thing in. That's it. I know my explanation is very vague, but I'm half-sleeping and english isn't my native language. Good luck with it.
Rennes
Omega 3.0 Sport Estate 1998
« Reply #4 on: 08 August 2008, 08:18:19 »
Have a look at this guide, it has a picture of the bulk head connections:
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204/0#0
trademeister
  • Rotherham
« Reply #5 on: 17 August 2008, 01:14:17 »
Thanks mate. Problem solved. Mark
Pete Elite
  • Uxbridge, Middlesex
« Reply #6 on: 17 August 2008, 01:26:03 »
  Hi Mark,
            Would you be able to put a drawing of where the pipes from the breather system connect up to, similar to the one you've done for the vacuum system?
       Thanks,
                 Pete.
« Reply #7 on: 17 August 2008, 08:46:57 »
Think its mostly covered here Pete.....although if there is any extra info that migh be useful then I will add it:
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
Pete Elite
« Reply #8 on: 18 August 2008, 19:27:30 »
          Many thanks Mark, helped a lot.
                          Cheers,
                                    Pete :y.
