Author Topic: Lambda Sensor 1  (Read 875 times)
Lambda Sensor 1
« on: 18 August 2008, 22:55:00 »
Hi guys
On a V6, does anyone know which o2 sensor is "lambda sensor one"?
Need to work out which lambda is flagging a fault on my car.
Just to make sure, I may swap 'em over and see if the fault changes to "lambda sensor Two".... :y
Re: Lambda Sensor 1
« Reply #1 on: 19 August 2008, 00:48:28 »
It's the cylinder 1 side.
Did you see Mark's post in your previous thread. Same side as EGR valve, and EGR valve also complaining...
I suspect a few minutes spent cleaning up / blanking off the EGR valve would save a few hours trying to remove the Lambda sensor. :y
