Author Topic: Strange Water leak from I dont know where!  (Read 1923 times)
jaylewis
« on: 18 August 2008, 11:22:52 »
Hello! I am new to the Forum, but urgently and desperately need help!
I have A GREAT 99 v 2.5 CDX. Just picked it up a month ago! Great car, but for one problem!
There is a water leak from somewhere down the back of the engine. Its the coolant that disappears in around a minute flat! Been into the garage, and I am told that there is a 'little hole right at the bottom of the V', and he is not too sure what it is! But it looks like a part that can be replaced!!! I have no idea...
Does anyone know what this might be, and whether it can be fixed???
Thanks, Jase. :-?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Strange Water leak from I dont know where!
« Reply #1 on: 18 August 2008, 11:37:42 »
First look at your Heater Bypass Valve (HBV), you will find a picture of it in the maintence section.
It is located behind the Plenum (big silver thing with ECO TEC on it)
These are a first port of call with a V6 water leak, price for a new one is around £30 from Vauxhall
Check it and let us know :y
« Last Edit: 18 August 2008, 11:38:44 by Loo-knee »
« Reply #2 on: 18 August 2008, 12:06:27 »
As Loo-Knee says check the heater by pass valve first, then I would check the oil cooler cover plate and thermostat which are both located in the V.
« Reply #3 on: 18 August 2008, 12:08:29 »
Thats a fast leak, so I'm guessing a hole in the oil cooler plate, or a problem with the transfer pipe to block seal. Or split pipe around coolant bridge.
Strip the plenum and intake off for a better look - see a thread in Maintenece Guides about cam cover gaskets, should be enough info to take all the intake off...
jaylewis
« Reply #4 on: 18 August 2008, 16:28:45 »
Thanks for all of your help, guys. I am guessing that it could be the cover plate with the garage saying that there is a hole...so I will have this checked and see how much it will cost to replace.
Thanks again, Jase.
« Reply #5 on: 18 August 2008, 18:48:32 »
Its doable DIY, just takes time...
jaylewis
« Reply #6 on: 19 August 2008, 15:05:52 »
I have another question! Been in touch with a few parts ppl, and finding it hard to get a plate! The nearest I have is an engine oil cooler, at £120! Is this the thing I need? Any ideas where to get one cheaper?
Thanks guys!
serek
  • huntingdon
    • 3.2 mv6
« Reply #7 on: 19 August 2008, 15:19:05 »
best way  use VX parts I pay 124£ for mine set for oil cooler with plate and all washer,
dont thing you can buy any chipper only with TC but still  90£
« Reply #8 on: 19 August 2008, 15:26:35 »
Got one in the garage you can have for the cost of postage
« Reply #9 on: 19 August 2008, 20:25:04 »
Cleaned up and ready to go
« Reply #10 on: 19 August 2008, 21:01:02 »
 i know its a pain but i would want to know what part has a hole in it first before i spend 100plus on something i may not need. Are we really saying the oil cooler cover plate has a hole in it? More likely a leak in the sealent? If it is that? A small hole at the back of the v... Could be a number of things.
Hbv, coolent bridge, transfer pipe? I have hurd mechs talk of warped cooler covers,(i didnt beleive them) but a hole? How would it get a hole?
« Reply #11 on: 20 August 2008, 08:55:54 »
I have seen a hole in the cooler plate before.
Item posted this morning so should be with you tomorrow (it should fit through most letter boxes!).
You will need the correct sealent and a number of seals to do the job, I guess the car is not useable at the monet so I would pop the plenum and inlet off to check for the leak just in case its the curly coolant pipe at the back failed.
« Last Edit: 20 August 2008, 08:56:13 by Mark »
Essex_Andy
  • Have a guess?
« Reply #12 on: 21 August 2008, 03:41:18 »
My money is on the cooler cover plate....mine holes through.
The plate costs about £20.
Just have your credit card ready for O-rings, banjo bolts and sealant.
Hylomar red or rtv on the plate. Ensure the mating surfaces are spotless and dry!!!!
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
« Reply #13 on: 21 August 2008, 08:34:40 »
Er no, nothing like the correct loctite stuff that is required!
Get the sealent from Vx  :y
Essex_Andy
  • Have a guess?
« Reply #14 on: 21 August 2008, 10:05:57 »
If they have any.....
My local dealer tried to palm me off with the green goo for the cam caps!!!!!!!!!!!!
So red hylomar it was and (touch wood) best part of 2 years later and all good
