Author Topic: Omega 2.2 petrol Temperature sender  (Read 1455 times)
mark readman
« on: 19 August 2008, 22:52:53 »
Where is the water temperature sender located on the 2.2 omega petrol engine please ?
Searched the usual haunts of around the thermostat, need to locate the sensor and check the wiring
trainmanone
  • stockport
Re: Omega 2.2 petrol Temperature sender
« Reply #1 on: 19 August 2008, 22:59:20 »
if its the same as the 2.0l its at the back of the engine near the dis pack bugger to change
pete
what was that ??????
mark readman
« Reply #2 on: 19 August 2008, 23:03:57 »
Whats a dis pack ?
sorry a bit dumn on forum slang, newby alert !
Is it a single wire ? as I expect the garage that have just done the normal new head gasket with omegas have left the wire off !
magnul
  • Trondheim, Norway
« Reply #3 on: 20 August 2008, 08:23:16 »
DIS=Distributorless Ignition System. It is the ignition module fittet to 2.0 engines based on "wasted spark", i.e. two coils where two cylinders share one coil. The 2.2 hasn't got a DIS pack as it is "coil per plug".
The temperature sender is a single wire, whereas the coolant temperature sensor is a twin wire.
« Reply #4 on: 20 August 2008, 08:58:18 »
If you look at the rear of the engine you ill see a couple of sensors mounted on a metal casting at the back, the single wire one is for the temp gauge in cabin and the two wire one is for the ecu.
What are the symptoms, I take it the car is getting upto normal operating temp?
mark readman
« Reply #5 on: 20 August 2008, 19:08:13 »
Just had the head skimmed, pressure tested and gasket changed, due to the dreaded pot 4 problem car running fine but temp gage in car reading zero, looks like I will have to remove the wipers and valance to get at it.
mark readman
« Reply #6 on: 21 August 2008, 20:18:50 »
Sorted ! bloody wire not out back on ! :D
Page created in 0.021 seconds with 16 queries.
