Author Topic: Bolt torque settings  (Read 1227 times)
eastwood
  • North East
« on: 23 August 2008, 10:48:50 »
Is there a list of torque setting on the forum?
specifically want the cam cover ones....
Stuart
shyboy
  • Southport, merseyside.
    • Mazda 6
Re: Bolt torque settings
« Reply #1 on: 23 August 2008, 10:57:40 »
Haynes manual lists them all in the appropriate sections.
Cam cover bolts are 8nm. and NO MORE!
eastwood
  • North East
« Reply #2 on: 23 August 2008, 11:06:44 »
ok Ill go for that!!!
cheers
Stuart
« Reply #3 on: 23 August 2008, 11:58:20 »
Not many torque wrenches go down to 8Nm, so you may need to borrow one.
Not using torque wrench will distort covers, causing them to leak.
« Reply #4 on: 23 August 2008, 12:36:39 »
myn goes to 8nm,i was very carefull to make sure i tightend all bolts and not over tighten, checked a week later and one was leaking around the bolt o ring, re torqued, it was quite loose, maybe 5nm but more than finger tight.
I then wondered if i remembered seeing something about re torquing after a week or so??? :-/ after the seels have compressed a bit. I did not look into it further as it did not cause any further probs. and i later sold the car.
