Pages: 1 [2] 3  All   Go Down
Author Topic: URGENT cambelt fitting help required!  (Read 6291 times)
Re: URGENT cambelt fitting help required!
« Reply #15 on: 21 August 2008, 22:04:33 »
foot on brake and acc to floor, turn to just before start, and watch the flashes :y
ok i get - including all flashes;
light goes out to start flashing, flash, flash, flash, flash out
4 flashes.  is this code 13 then?
not enough of the sequence - there will be more flashes
rawsondsr
  • Near Dartford & Reading
« Reply #16 on: 21 August 2008, 22:20:32 »
btw all flashes are 1-2 seconds apart.
not flashflashflashflash but flash     flash     flash     flash
i'll go check again
no its just the four, unless the rest follow 2-3 minutes after?
code 1111 possibly?
« Last Edit: 21 August 2008, 22:29:23 by rawsondsr »
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #17 on: 21 August 2008, 22:31:37 »
i'll go check again
code 1111 possibly?
do you mean:
flash
flash flash flash?
which would = 13
usuay repeated 3 times then moves on to next code or back to the begining (well that's what it does on a 3.0)
rawsondsr
« Reply #18 on: 21 August 2008, 22:35:24 »
that might be it - each flash is 1-2 seconds apart and they dont repeat, well not within 1-2 minutes they dont
HerefordElite
  • Hereford
« Reply #19 on: 21 August 2008, 22:39:13 »
each digit is seperated by a small gap hence my
flash
flash flash flash :y
still need to confirm that later y26se engine uses same ecu and codes
anyone? ::)
rawsondsr
« Reply #20 on: 21 August 2008, 22:41:07 »
each gap is the same if it makes any difference
« Reply #21 on: 21 August 2008, 22:42:06 »
flash
anyone? ::)
 I wasn't aware you could flash codes on a 2.6, as it's DBW?
HerefordElite
  • Hereford
« Reply #22 on: 21 August 2008, 22:47:09 »
flash
anyone? ::)
neither am i?
 but have heard of the press brake and acc and turn key trick before, but obviously only use a trust paperclip on mine
sorry if this ain't helpin rawsondsr but it's keeping your prob at top of list with lots of replies where someone more knowledgeable will notice :y
« Last Edit: 21 August 2008, 22:47:30 by herefordelite »
« Reply #23 on: 22 August 2008, 08:30:34 »
2.6 and 3.2 can be flashed using a trick with the pedals.
BOTH use a 4 digit code to comply with EOBD/OBDII
rawsondsr
« Reply #24 on: 22 August 2008, 08:51:58 »
so is mycode 1111 then do you think/
« Reply #25 on: 22 August 2008, 08:57:16 »
If it is 1111, check the rear multiram electrical connector is plugged in ;)
rawsondsr
« Reply #26 on: 22 August 2008, 08:58:14 »
where is that one ta/
« Reply #27 on: 22 August 2008, 08:58:55 »
right rear of plenum, partly obscured by scuttle...
« Reply #28 on: 22 August 2008, 08:59:47 »
1111 is valve 2 which is the front one.
rawsondsr
« Reply #29 on: 22 August 2008, 09:01:46 »
which is... :-? :-[
a plug near the front?
Pages: 1 [2] 3  All   Go Up
