Pages: [1] 2 3  All   Go Down
Author Topic: URGENT cambelt fitting help required!  (Read 6288 times)
rawsondsr
  • Near Dartford & Reading
« on: 21 August 2008, 15:47:35 »
put new belt on, timed it up, went to turn crank over, got a bit stiff, and then it slipped a notch or so many.  what do i do now?  turn crank back and reset timing with kit? or what?
help!
jonathanh
  • coventry
Re: URGENT cambelt fitting help required!
« Reply #1 on: 21 August 2008, 15:58:12 »
I think you failed to set the tension on the belt before you turned over.
My advice would be to try to turn the crank back to TDC, and the cams back to get the cam locks in.  turn cams and crank carefully - if you get resistance (i.e. values and pistons meeting) then you have problems! do not force it
« Reply #2 on: 21 August 2008, 16:44:20 »
Don't turn the crank backwards with the belt on.
Best course of action is to remove the belt, turn the crank to either 60 degrees before or after the TDC position, whichever is closest and lock the cams back in their correct positions, then turn the crank back to the TDC position and fit the belt again.
If, at any point, there is resistance to turning anything, don't force it.
rawsondsr
« Reply #3 on: 21 August 2008, 17:35:31 »
ok, ive got it all set up again, but i get to a point where it just wont turn at all - ive cocked this up havent i?
there are two lines on all the cam gears - is there a certain one that has to line up?
i think i need present help with this one :'(
« Reply #4 on: 21 August 2008, 17:38:51 »
When you start, the cut out on the bottom pulley should be at 6 o clock, and cam 1 lmarking ined up with rear cambelt cover, and so on for the other cams..
Can you confirm this is/was the case?
« Reply #5 on: 21 August 2008, 17:40:01 »
There are numbers on all the cam markings, starting from number 1, the numbers 1 through to 4 respectively need to line up with the rear cover marks...
rawsondsr
« Reply #6 on: 21 August 2008, 17:53:49 »
1, 2, 34, 34 are in the same alignment, now about a 1/4 of a turn round where its met with resistance
« Last Edit: 21 August 2008, 17:54:17 by rawsondsr »
jonathanh
  • coventry
« Reply #7 on: 21 August 2008, 19:39:08 »
Whatever you do, do not force it.
as to the cam timing, you need, working from left to right, mark 1 on left, then mark 2, then mark 3 then mark 4 on the right hand cam.  It is very easy to get the wrong marking lined up.  you think it is right but it is not.
sorry but I'm not around this weekend but possibly can help out next weekend if you want, depends where you are, Reading is good for me.
If i were you (and I was in exactly your position recently) I would want an experienced eye to look at this
If you take some pics and load them up maybe we can help remotely.
Just take your time and you will get there
rawsondsr
« Reply #8 on: 21 August 2008, 21:23:01 »
well i managed to re time the lot from scratch, and its running, got an error code though - i know how to see it but i dont know how to know what the code means?
« Reply #9 on: 21 August 2008, 21:24:38 »
What's the code.
Well done on the belt.
rawsondsr
« Reply #10 on: 21 August 2008, 21:29:28 »
whats the sequence i.e. when does the actual code start/fininsh/
ta, nothings ever simple with me! 10 hours1 :'(
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #11 on: 21 August 2008, 21:30:54 »
1, 2
1 , 2
1, 2 is diagnostic start then code...
HerefordElite
  • Hereford
« Reply #12 on: 21 August 2008, 21:36:31 »
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
codes are here :y
but you got a facelift 2.6 how are you reading codes? :-[
« Last Edit: 21 August 2008, 21:39:54 by herefordelite »
rawsondsr
« Reply #13 on: 21 August 2008, 21:45:35 »
foot on brake and acc to floor, turn to just before start, and watch the flashes :y
ok i get - including all flashes;
light goes out to start flashing, flash, flash, flash, flash out
4 flashes.  is this code 13 then?
HerefordElite
  • Hereford
« Reply #14 on: 21 August 2008, 21:51:28 »
sorry if i'm not helping - don't know if 2.6s code are the same as 2.5&3.0 (bosch motronic 2.8.1) ??
if is the same remember code 31 (no rpm signal) should be ignored if engine not running
(i'm trying to help honest :-[)
Pages: [1] 2 3  All   Go Up
