Author Topic: v6 keeps cutting out  (Read 794 times)
hairyguy4
« on: 23 August 2008, 18:41:49 »
my omega drive belt had snapped and the car overheated, i replaced the drive belt, had the head gaskets replaced and all new belts, since then it has started cutting out and not refiring till about 15-20 mins later and then starts fine and then happens all over again
i have replaced the coil pack and has a new camshaft censor, problem still occurs
anyhelp aprecciated
Re: v6 keeps cutting out
« Reply #1 on: 23 August 2008, 19:57:49 »
what v engine is it? Might be crank sensor, look for paperclip test in maintenance section. Code 19 iirc for p clip test, cant remember the pedal trick code. If not clean the icv. If its related to the work thats been done, maybe have a look for damage the flying belt may have caused, there as a phew vac pipes and elec. plugs in that area. Hope
helps.
« Last Edit: 23 August 2008, 20:03:26 by chrisgixer »
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 23 August 2008, 21:42:09 »
If its a V6 then its likely to be crank sensor code 19 as stated.
As said try paper clip test if yours is 2.5 or 3.0 ;)
