Author Topic: Play in a wheel  (Read 2093 times)
Play in a wheel
« on: 23 August 2008, 17:23:10 »
Drivers side front wheel - when rocked at 12 o clock there is some vertical play. This occurs with brake on or off.
Is this likely to be a wheel bearing? Do we have a guide or am I being blind?
Dazzler
  • Haverhill, Suffolk
Re: Play in a wheel
« Reply #1 on: 23 August 2008, 17:25:14 »
Sounds like a wheel bearing to me.
Never seen a guide to be honest :-/
Sold as hub assy from Vx, about £82+vat, and easy to change like that ;)
Re: Play in a wheel
« Reply #2 on: 23 August 2008, 17:25:56 »
Just found the guide - cheers mate :y
Still interested on opinions as to cause, though :y
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: Play in a wheel
« Reply #3 on: 23 August 2008, 17:28:02 »
Re: Play in a wheel
« Reply #4 on: 23 August 2008, 17:31:58 »
http://www.omegaowners.com/forum/YaBB.pl?num=1175890350
too slow :-[ ::)
No worries mate - it looks really easy, TBH.
My only concern now, is finding a torque wrench that can go up to 320nm ;D
Dazzler
Re: Play in a wheel
« Reply #5 on: 23 August 2008, 17:35:22 »
too slow :-[ ::)
Or two sets of white knuckles and the breaker bar ;D ;D
Re: Play in a wheel
« Reply #6 on: 23 August 2008, 17:36:50 »
too slow :-[ ::)
Scaffold pole? ::)
It did cross my mind - how important is it to get this accurate? Is 'effin tight good enough, or is it a precise thing?
Dazzler
Re: Play in a wheel
« Reply #7 on: 23 August 2008, 17:40:46 »
Well you know my answer to that one James ;)
HerefordElite
  • Hereford
Re: Play in a wheel
« Reply #8 on: 23 August 2008, 17:43:07 »
too slow :-[ ::)
Scaffold pole? ::)
sh1t :o that's tight
just been out to check mine and it only goes up to 140Nm :-?
Re: Play in a wheel
« Reply #9 on: 23 August 2008, 17:43:42 »
I was taught a lot of what I know by an old farm hand - it's probably why I spent a couple of weeks shearing off bolts when I started working on modern cars ;D
I think my hand is quite well calibrated now, though, after 3 years or more of Omega DIY Ownership :y
Dazzler
Re: Play in a wheel
« Reply #10 on: 23 August 2008, 17:45:03 »
You wont shear that one matey ;D
Re: Play in a wheel
« Reply #11 on: 23 August 2008, 17:47:02 »
too slow :-[ ::)
Scaffold pole? ::)
Play rocking at 12 o'clock/6 o'clock usually wheel bearing.
320Nm  :o - long pole and 'effin tight.  Big hammer may also help!!
Re: Play in a wheel
« Reply #12 on: 23 August 2008, 17:47:15 »
;D
Is the back bearing a lot more difficult to do?   :question
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: Play in a wheel
« Reply #13 on: 23 August 2008, 18:48:27 »
;D
[/highlight]
Yes unless you have the correct kit its a pain in the backside even with a fully equiped workshop.
And on the original question  if theres play in the wheel bearing it normaly disapears when the brake is applied.
lee
« Last Edit: 23 August 2008, 18:59:24 by lee4206 »
Omegatoy
  • UK
Re: Play in a wheel
« Reply #14 on: 23 August 2008, 21:50:16 »
Damn beaten to it!!! play with no brake applied usually disappears when brakes applied= wheel bearing play still there usaully means a ball joint, and i have a torque wrench that does them goes up to 350!!
more to the point tho the bearings are servieable just in case anyone doesent know? they come apart fairly easily so you can clean out old grease and regrease just be careful of the grease seals!!
Omegatoy
« Last Edit: 23 August 2008, 21:50:34 by Omegatoy »
Page created in 0.059 seconds with 16 queries.
