Author Topic: omega tyre size  ????  (Read 1930 times)
mustangboy
« on: 23 August 2008, 21:57:34 »
Hi anyone know if i can fit 225/60-16 to the rear of my omega.  currently has 225/55-16s
MutantCav
  • Gainsborough
Re: omega tyre size  ????
« Reply #1 on: 23 August 2008, 22:01:11 »
Whats wrong with fitting the correct size? Would look better anyway as lower profile...
If fitting different sizes you would need to change both tyres to the 60 low profiles at least
« Last Edit: 23 August 2008, 22:04:35 by ShieldOfSteel »
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 23 August 2008, 22:56:19 »
The difference would be small, about 22mm in the diameter of the tyre, so do-able. I wondered why you wanted to fit them, perhaps you have some cheap, fair enough reason. Fitting on rear only? What size spare are you going to carry? It will lift the back of the car a little. I suppose as long as you can justify it, 225/55/16 is normal size Omega tyres.
markomega25
  • Morden, Surrey, A3 gateway
« Reply #3 on: 23 August 2008, 23:15:16 »
I found a good guide to tyre equivalence on the web when i was looking to replace mine. I think the important thing from a legal perspective is the need to make sure the speedo is not registering less speed from standard recommended sizes, or more than 3% difference.
The website below tells it better than i could for sure and is very informative.
http://www.pneus-online.co.uk/tyre-equivalence-advice.html
A quick look shows that replacing your 225/60's with 225/55's would mean you are reading 3.4% less on the speedo than you were or possibly should. Speedo should be re-calibrated. But you must check what the standard fittment should be to start with first, then compare with your preferred choice.
Hope that helps.
Mark
markomega25
« Reply #4 on: 23 August 2008, 23:30:31 »
Oops, just re-read your post (got the sizes the wrong way round in my reply so did a re-check).
Fitting 225/60's instead of your current 225/55's mean your speedo is reading 3.4% less.
It is all about percentages, a 55 profile is a smaller tyre in radius than a 60 for a set width/diameter. So as Agemo says, fitting a 60 would raise the car by a little, because it is a larger diameter tyre - hence you are travelling more per revolution of the wheel than before so speedo under estimates speed.
