Author Topic: ENGINE FAULT CODES FOR 3.2 V6  (Read 1259 times)
skippybanger
  • bedford
« on: 24 August 2008, 14:57:10 »
hi i am going to do the pedal test on my 3.2 mv6 has anyone got a list of the fault codes
Re: ENGINE FAULT CODES FOR 3.2 V6
« Reply #1 on: 24 August 2008, 15:52:32 »
Think these are Simtec controllers (??)
If so 4digit fault codes as below -
0100 Mass air flow sensor
0105 Intake manifold pressure sensor
0110 Intake air temperature sensor
0115 Intake coolant temperature sensor
0120 HEGO heater
0150 HEGO
0173 HEGO
0201/020/0203/0204/0205/0206 Injector 1/2/3/4/5/6
0230 Fuel pump
0325 Knock sensor
0330 Knock sensor 2
0335 Crank sensor
0340 Camshaft sensor
0351 Ignition coil 1+4
0352 Ignition coil 2+3
0400 EGR valve
0403 EGR valve
0410 Secondary air pump relay
0412 Secondary solenoid valve
0433 Fuel tank vent valve
0500 Odometer frequency sensor
0505 Idle speed stepper motor/idle air regulator
0560 Battery
1110 Switch over valve solenoid
1112 Switch over valve 1
1113 Switch over valve 2
1120 Throttle body malfunction
1229 Power supply relay
1231 Fuel pump relay
1320/1327/1328/1329 Knock control cylinder 1/2/3/4
1405 EGR valve
1410 Secondary air pump relay
1411 Secondary air pump
1501/1502/1503 Immobiliser control unit
1530 Air flow relay
1600 Internal control module
1601 ECU temperature high
1602 Knock control module
1604/1605/1606 Knock control unit
1640 Knock control unit or quad drive module
1690 MIL/Engine fail (malfunction indicator lamp)
1740 Torque control unit
If this is wrong, someone will soon correct me.
    • 530D M Sport, 330i Coupe
« Reply #2 on: 24 August 2008, 16:12:36 »
Post any codes up and we will advise!
« Reply #3 on: 24 August 2008, 16:13:29 »
post up results and I'll look them up.  I haven't had time to produce a conclusive list yet
mark readman
« Reply #4 on: 24 August 2008, 18:58:43 »
All cars sold in uk post year 2000 must be OBDii compliant by law
I have a full list of P codes however I can only post 6000 bits so can not post it up
« Reply #5 on: 24 August 2008, 19:33:18 »
Don't worry, I'll post up the Omega ones in a day or 2.  Generic P codes aren't that useful, as the OBDII standard has too much scope for manufacturer specific.
And it was 2001 for petrol and 2003 for tractors ;)
skippybanger
  • bedford
« Reply #6 on: 24 August 2008, 19:41:27 »
thanks everyone
« Reply #7 on: 24 August 2008, 19:43:49 »
For information the ECU is Bosch Motronic 3.1.1
