Author Topic: V6 Multi-Ram Question  (Read 1458 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« on: 24 August 2008, 17:06:28 »
Have been having a few problems with poor running and bad fuel economy with my mv6 had a look under the bonnet and have noticed a multiram vacuum lead is broken and so has the ECU plug part of it
its the one on the front it opens a flap up to make both intakes one! the connector that the lead plugs into a little solonoid with an ECU plug and another vacuum plug its made by EATON i replaced it with one off a 2.5 at a scrappie same p/n so assume its the same
what does it do? and is it the reason why my mig does 15mpg!
Re: V6 Multi-Ram Question
« Reply #1 on: 24 August 2008, 17:23:57 »
It adjusts the inlet length, to flatten the torque curve
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 24 August 2008, 18:18:22 »
it does feel more tourqey is there anyway of testing the multiram?
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #3 on: 24 August 2008, 19:16:37 »
no that's just the way you drive Tom ;)
johnnycboy
  • Colchester
« Reply #4 on: 24 August 2008, 20:06:09 »
tmx
iirc, give the throttle a good blip should operate at about 4000rpm.
hth :y
« Reply #5 on: 24 August 2008, 20:56:11 »
It increases low down torque quite considerably, this will help cruising mpg
Page created in 0.199 seconds with 16 queries.
